Fuel Pump, or pumps
Old Jan 12, 2008 | 07:26 AM
wayneF250's Avatar
wayneF250
Fuel Pump, or pumps
I have a 94 F250 4x4, are there TWO fuel pumps, sence the truck has Two fuel tanks??? And I've done several mods to engine, Cam, Heads,injectors, etc.... What "size " GPH pump should I get???
Old Jan 12, 2008 | 08:08 AM
subford's Avatar
subford
What is wrong with the ones you have?
Old Jan 12, 2008 | 11:04 AM
Conanski's Avatar
Conanski
What are the stock pumps capable of pushing... 80-90gph maybe? And what does that convert to in HP on a V8 motor? I see some Google searching in my near future. If you have done enough to the motor to require bigger injectors then it's quite possible you need more pump. Problem is, the resovoir the pump is enclosed in won't take a physically larger pump.. and most of the higher volume aftemarket pumps are too big in 1 dimension or another and won't fit. The resovoir contains check valves by the way which prevents fuel transfer between tanks, so you can't just remove it. Maybe an external inline pump on the frame is the solution..
Old Jan 12, 2008 | 11:55 AM
subford's Avatar
subford
A stock fuel pump puts out 33 GPH and will pump up to a 95-PSI head.
If he needs more that he could wire both fuel pumps to run at the same time.
Old Jan 13, 2008 | 08:40 AM
wayneF250's Avatar
wayneF250
my fuel pump is going out, the truck dies, just for a sec. when u mash the gas, and gives a code 87 I think, "failed circut @ fuel pump" . Since i've done some mods to engine ....E303 cam, 30 lb injectors, MAF conversion, Edelbrock heads. I was wondering should I go back w/ stock pump. Dont the truck have 2 fuel pumps, since it has 2 tanks. Or do I just replace the stock pump, and add a inline pump to help pressure.....also w/ a pressure gage connected to the fuel rail, what pressure should I have on this engine
Old Jan 13, 2008 | 09:13 AM
subford's Avatar
subford
With pin number 6 of the test connector grounded and the key on and the engine not running you should get about 42 psi.
Also with it running (idling) and the vacuum hose off the nipple of fuel pressure regulator you should get the 42-psi.
At idle with the hose on the regulator you should get about 32-35 psi.
WOT again about 42 psi.
Yes if you have two tanks you would have two fuel pumps, one in each tank.
The "failed circuit @ fuel pump" a lot of times turns out to be a bad fuel pump.
Old Jan 13, 2008 | 09:51 AM
wayneF250's Avatar
wayneF250
So the solution is to replace the pump w/ a stock pump, and add an inline pump to boost up pressure??? also the truck has 208,000 miles w/ factory pump.......bet the sock filter is a little dirty....u think?
Old Jan 13, 2008 | 10:10 AM
subford's Avatar
subford
I do not think you ever said what size engine you have.
A stock pump will put out enough for a 460 engine.
To get higher fuel pressure you need to replace the fuel pressure regulator with an adjustable fuel regulator.
Adding a pump will not increase fuel pressure but it may or may not increases volume.
How many GPH do you want anyway?
rangergirl94
18
Jun 10, 2017 09:17 PM
I6satx
May 16, 2014 11:26 AM
justinf-250
Feb 18, 2011 05:21 PM
74hiboy
16
Jul 7, 2007 05:18 PM
