6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Uphill Towing during Regen
Old Jan 12, 2008 | 06:09 AM
05F350CC's Avatar
05F350CC
Question Uphill Towing during Regen
Hi All,
Well I am planning my summer travels with my fifth wheel and I was wondering if one of you mechanical-types could answer a question...
If I am towing my fifth wheel up a pretty steep hill and it starts a regen, is there a noticeable loss of power? The mountain I will be climbing is a pretty good climb (which is one of the main reasons I went with this truck) but in reading through some info on the regen process, it leads me to think there mayu be some power loss...hate to get halfway up this mountainside and lose power!
Should I be concerned??
Old Jan 12, 2008 | 08:41 AM
Creekowl3's Avatar
Creekowl3
The truck will be working hard to pull up the hill and will not go into regeneration.
Old Jan 12, 2008 | 08:45 AM
richfaa's Avatar
richfaa
From personal experience towing a 13K + fifth wheel. We can see the regen via the pre turbo egt as the ET's increase by 300/400 degrees. We did have to back off as the Et's got very high 1300 + and boost wanted to increase but we had no notciable loss of power other than we had to slow down to keep the EGT's within acceptable range. IMO a Pre turbo EGT is a requirement if pulling heavy loads.
Old Jan 12, 2008 | 08:53 AM
rrrmotorsports's Avatar
rrrmotorsports
Smile
With the trailer on (18,000) going up a steep grade my truck will go into regen and slow down 15 - 20 mph flat on the floor. I have been in the mountains out west running 45 mph flat on the floor. When the truck is not in regen it runs night and day different. The oing alot of regens after it got to about 6000 miles on it. My dealer has been working on this problem for the last 14,000 miles. I can't wait till somebody comes out with a DPF bypass.
08F350 DRW
Old Jan 12, 2008 | 03:08 PM
SANDDEMON08's Avatar
SANDDEMON08
I am curious if you are running a tuner, i have towed 12,000 Lbs out of Laughlin NV during the summer 116+ degrees and never had to back out of it. I think its a 6% grade about 20 miles long.
If i am not mistaken, the Ecm will start defueling At 1200 degrees automaticly
Old Jan 12, 2008 | 09:08 PM
fordfish's Avatar
fordfish
ECM better cut back we aint got no stinking gages. This green diesel is makin me red
Old Jan 13, 2008 | 10:12 AM
richfaa's Avatar
richfaa
It is a stock motor..and you are correct as to what is says about de fueling at 1200 degrees. However that is not what I saw. My EGT guage is set to alarm at 1250 and it went right by so I backed off. We did find later that we had a bad DPF which was replaced,
Old Jan 13, 2008 | 10:19 PM
brandon4's Avatar
brandon4
My truck regened terrible w/7k lbs behind on I70 in Utah. Probably only 35 mph. I yanked the dpf and got a tune and now it flies up that hill. Doesn't even shift at 75 mph.
Old Jan 14, 2008 | 11:40 PM
05F350CC's Avatar
05F350CC
Well it seems that this is another of those areas of uncertainty that I seem to fall into! Some controversy here about this regen thing while towing. Since few of you know of the mountain I am facing, it's understandable.
Guess I will find out this summer whether I will lose power on this climb if and when the truck kicks into regen!
BTW, what is a DPF and what does it do? What happens when it's taken off (aside from the warranty thing)?
Old Jan 15, 2008 | 12:27 AM
SANDDEMON08
Well when your truck goes into re-gen the motor is de-rated 50+ hp. The DPF traps the soot(Black smoke) in your exhaust making your truck burn clean no smoke. When a sensor reads high back pressurein the DPF, the computer starts an active regen. During active regen additional fuel is added to the exhaust to rise the exhaust to around 1,000 degrees. At that temp the soot in your DPF turns to ash thus cleaning the DPF.
While driving normal the truck is in passive regen which while towing should keep the exhaust hot enough to keep the DPF clean.
You can not take the DPF your truck without re tunning the ECM to turn regen off. If you re tune it, it would smoke a little depending on the tune and you should see better fuel ecomony. There is also the issue of smog, your truck will not pass smog without the DPF. There are loop holes in some states regarding the smoging depending on the GVW rating of your truck.
If you change your exhaust keep all the old parts. The stock exhaust cost about 3,800.00 to replace(dealer price) not includeing labor.
Hope this helps.
Old Jan 15, 2008 | 07:44 PM
hodgekuter's Avatar
hodgekuter
I would think that when pulling and running good and hard that the DPF would keep itself clean without so many regen cycles. Yes-No ??
Bill in KY BTW Mine hasn't gone into regen yet.
Old Jan 18, 2008 | 06:08 AM
05F350CC's Avatar
05F350CC
Uphill Towing During Regen - UPDATE
Ok just found out from a relaible source that the mountain I am wondering about (Thompson Pass) is a 7.5 mile pull averaging a 7% grade.
Now with that info and pulling a fiver that is less than 10,000 lbs (that is the GVWR for my fifth wheel which I am certain I am under), do you think I will have a regen during the pull and if so, will I lose any power during it.
How do you think my stone stock F350 CC LB Dually "Tow Twuck" will do on this tug?
Old Jan 18, 2008 | 07:21 AM
richfaa's Avatar
richfaa
The probabilities that you will have a regen during any pull are slim IF the DPF is operating properly..Again...check your tailpipe..if there is black soot..the DPF is defective..If the DPF is defective the overall performance of the truck will be...real...bad..During a long hard climb you will need to watch your EGT's and boost and you MAY have to back off to keep them within safe limits.
Old Jan 18, 2008 | 09:23 AM
firehawk198's Avatar
firehawk198
towed about 17k over 2,000 miles this summer and for a total of 3,000 miles never felt it go into regen, For the most part it should be running hot enough, but as you read there are some people that are still going into regen. I wouldn't be too concerened about it. Just found heading up the bigger hills the electric fan would increase rpms and sound like a 747 was landing on your roof. Couldn't be more please towing our 5ver. Just can't wait to go again.
Old Jan 18, 2008 | 08:44 PM
05F350CC's Avatar
05F350CC
Well I don't have an EGT gauge mounted yet...it's on my "to do" list but I don't know that I'll have it done by travel time. I want to put the Big Three gauges on the truck - EGT, Trans Temp, and Boost gauge. But that is $$$ I don't have at the moment - I still got to get the hitch moved over to the new truck or we won't be going anywhere!
