Air in Fuel system
Old Jan 11, 2008 | 12:11 PM
gbratto's Avatar
gbratto
Air in Fuel system
I have a 2002 7.3L and I replaced the fuel filter and now the truck will not start, I vented the filter housing (had fuel spitting out as I tightened the cap, but the truck will not run any suggestions? It tries to start.
Old Jan 11, 2008 | 12:30 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
Turn the key on and listen for the fuel pump under the drivers seat on the frame rail. You might cycle it twice. Then try to start it.
Old Jan 11, 2008 | 12:58 PM
Kwikkordead's Avatar
Kwikkordead
Welcome to FTE.
You need to read this:
https://www.ford-trucks.com/forums/4...-the-tank.html
Old Jan 11, 2008 | 03:02 PM
dave1321's Avatar
dave1321
i work on fleet trucks same thing happend on the frame rail under drivers floor there is a in line fuel pump tap it a couple times with a hammer it should go.
