I have 79 f350 with a 351 modified. My problem is with charging the battery, when the voltage regulator is disconnected the battery has 12.5 volts in it with the engine off, when I connect the voltage regulator up the battery goes up to 13.4 volts with the engine off.When I turn on the engine the battery is up to14.7 volts
