piston valve clearance
Old Jan 10, 2008 | 08:26 PM
leftystar's Avatar
leftystar
Question piston valve clearance
I have dooe c heads that have been milled even with the valves got em cheap i have a factory flat top piston came off of a 86 5.0 , supposely has 512 lift on the intake without the rockers installed to put a thin peice of stirofoam like come with a burger about thick as a nickle and turned the motor and it left a very lite indention on the stirofoam (didnt have puddy on hand) and im wondering do yall think i'll have a clash
Old Jan 10, 2008 | 10:17 PM
Conanski's Avatar
Conanski
I don't know what you're asking but I'm hungry for a burger for some reason.
Old Jan 10, 2008 | 10:23 PM
Conanski's Avatar
Conanski
Valve clearance is about cam duration as much as valve lift, because it really doesn't matter how far the valves open when the piston is at the bottom of the hole. You need to assemble the complete valvetrain for at least 1 cylinder and rotate the motor through a full cycle to determine if there is a clearance problem. You also need to disassemble a lifter and stuff it solid so you get an accurate reading of what happens when the motor is under oil pressure.
Old Jan 11, 2008 | 04:52 AM
baddad457's Avatar
baddad457
Problem with styrofoam is it doesn't stay compressed. Your mix of heads, cam and pistons with no valve reliefs spells dissaster with it running. The reason those pistons didn't need reliefs was the valves in the heads used with em were 1/8" farther away from the deck. They're sunk deeper into the E6SE heads.
Old Jan 11, 2008 | 06:33 AM
LxMan1's Avatar
LxMan1
Yep, I would use 87-92 Forged pistons from an HO engine.
Old Jan 12, 2008 | 11:16 AM
leftystar's Avatar
leftystar
what about using headgasket spacer shims???
and size?
Old Jan 12, 2008 | 12:23 PM
leftystar's Avatar
leftystar
I have some e7 heads i can use do you all see any problems with them
Old Jan 12, 2008 | 03:15 PM
baddad457's Avatar
baddad457
E7's will not change anything enough to clear those pistons. All you're gaining is a slightly smaller valve as far as clearance goes. Headgasket spacer shims? Never heard of them. Thicker head gaskets can gain you clearance but at the cost of a lowered compression ratio. Do the job right and change pistons.
Old Jan 12, 2008 | 03:20 PM
HemiEater's Avatar
HemiEater
I'd change the pistons or keep the cam small enough... you might be ok with 500 lift but like what was stated its the duration that matters although they go hand and hand... big lift big duration...
if you can use heads that have not been decked and use the thickest gasket you can find....then try and keep the preload to a minumummmmm..lol the more preload on the lifters the more the valve will open if you miss a gear and float the valves... 1/8 to 1/4 turn max..
and you should have at least .100 clearance on the exhaust and .080 on the intake...
if the heads are off grind some reliefs in the pistons....just make a template and grind away just need to do the exhaust... most cams for sbf will have a higher lift and longer duration on the exhaust side thanks to the wonderful heads they made...
Old Jan 12, 2008 | 08:37 PM
leftystar's Avatar
leftystar
do they make studs for roller rocker that will screw in to the existing bolt holes that are on the factory heads instead of getting them machined im running out of time we race jan 23 golden isle speedway
Old Jan 12, 2008 | 08:52 PM
Talltruck's Avatar
Talltruck
Comp Cams makes studs to go from a pedestal rocker to an adjustable setup, but you'll also need adjustable type rockers.
Old Jan 12, 2008 | 09:01 PM
leftystar's Avatar
leftystar
i have got rollers
Old Jan 13, 2008 | 12:05 AM
baddad457's Avatar
baddad457
Yea, they do, but they're not what you'd want to rely on in with anything more than the pedestal rockers will handle in terms of cam profile and spring pressures. You'll still have a tiny assed 5/16" bolt holding the rocker to the head.
Old Jan 15, 2008 | 11:18 AM
s1120's Avatar
s1120
Ditch the styrofoam idea. Do it right. Mock up a full valvetrain, and test it right. Thats a lot of lift for 1.84 valves on a stock 86 piston though. It might clear depending of duration, but I would not bet on it. I just swapped in a cam with 544 lift, and I am running a HO shortblock with valve notches, with the same heads as you with 1.94 valves, and I hit. I had to lay the eyebrow back a little. So learn how to check it, and do it right, or stick with stock. Or risk it...
cws10190
Sep 9, 2014 10:22 AM
cws10190
Nov 7, 2012 09:36 AM
Piper106
Oct 30, 2005 03:42 PM
Purely Ford
18
Nov 24, 2004 12:46 AM
