For the Lightning guys. A friend of mine has a Gen 1 clone. He has black lug nuts on the wheels and it looks sweet. I think it matches the truck since it has black door handles and mirrors etc.
sounds like it would be a pretty good accent peice.
I figured it would be. Im planning on making the stripe one inch bigger to cover anything up... then I will buy some stripes to cover the transition...
That's odd. If it's a truck bound for Canada it will have them. Maybe someone disconnected them or removed the relay. If you do a search you'll find out where the relay is.....I can't remember.
Hey, what's that plug by the passenger headlight? I have one too and it says Canada on it. Is it for a block heater? It's wires are tied into the truck wiring and then to something on the side of the passenger side of the block.
ya mine is a block heater but there are also pan heaters that will look the same but go into the oil pan but since yours is on the block its a block heater i usually tuck the cord into the quarter panel beside the battery since i never have to use it
