Sponsored by: Real Truck
Powertrain control module
Old Jan 10, 2008 | 02:32 PM
Wreck®'s Avatar
Wreck®
PCM
01 F350 Deisel, where is it located?
Thanks in advance.
Old Jan 10, 2008 | 02:43 PM
cartmanea's Avatar
cartmanea
Left inner fender, ahead of the power steering reservoir. Has three large plugs on the side that faces the engine.
Old Jan 10, 2008 | 02:59 PM
rbaker6336's Avatar
rbaker6336
it's actually under dash kinda beside parking brake
Old Jan 10, 2008 | 03:08 PM
Wreck®'s Avatar
Wreck®
Thanks, you da man
Old Jan 10, 2008 | 03:12 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Originally Posted by Wreck®
PCM
Thanks in advance.
Ray is right. If you take it out you do need to take the bolt off the wireing under the hood against the firewall, in the drivers corner.
EDIT: Welcome to FTE , Wreck
Old Jan 10, 2008 | 03:15 PM
cartmanea's Avatar
cartmanea
Sorry, I assumed it was in the same place as my '03. And you know what happens when you ***-u-me.
