Leaf Sag??
Old Jan 10, 2008 | 10:52 AM
DOUBLEF222's Avatar
DOUBLEF222
check to see if your spring pearches are in the same spot on both sides. mine was doing the same thing. come to find out that my main leaf was broke and was causing the sag. mine was broke under the u-bolt plate behind the u-bolt,so i didnt find until i took it apart.
Old Jan 10, 2008 | 09:35 PM
JRCF's Avatar
JRCF
I have a good set of 3" wide stock springs including all shackles and mouning brackets with the stock blocks of my 1995 I scraped. Thinking about putting these in my 2wd, this should allow me to carry more weight right?
What would this do for the stance of the truck? front has heavy duty coils in now,
will I need new shocks?
So many questions!!
Old Jan 10, 2008 | 10:16 PM
95F350XL's Avatar
95F350XL
What are the 3" from? If from a F250 or F350 you can carry more, if its from a F150 then na I should be the same as now. Unless 4x4 F150 has 3" then it might be more heavy duty. If it sits higher you might need new shocks, if it sits the same then nope ur fine.
balingwire
Sep 3, 2015 11:06 AM
shameless
Oct 25, 2014 11:57 AM
stephen.osborne1
2009 - 2014 F150
Jan 17, 2014 02:57 PM
mooktank
Offroad & 4x4
Jan 16, 2003 05:51 AM
