Injectors
Old Jan 9, 2008 | 04:15 PM
SuperSnake's Avatar
SuperSnake
Injectors
Can the Fuel Injectors be rebuilt? 5.0 EFI
Old Jan 9, 2008 | 04:40 PM
subford's Avatar
subford
Yes they can.
Search ebay for "fuel injector kit".
Old Jan 9, 2008 | 04:42 PM
SuperSnake's Avatar
SuperSnake
Originally Posted by subford
Yes they can.
Thanks subford I will. Are they easy to rebuild?
Old Jan 9, 2008 | 04:47 PM
subford's Avatar
subford
Here are the installation instructions -
  • During the entire process, be very careful not to drop the injector or damage the fragile pintle end of the injector in any manner. Also, do not allow any dirt to enter the injector.
  • Use a small pick to remove the old o-rings. Roll new o-rings on with your fingers. The black o-rings go on the top (fuel inlet) of the injector, the brown o-rings on the bottom.
  • The correct order of parts on the bottom of most injectors, starting at the bottom end, is pintle cap, o-ring, yellow spacer.
  • To remove the inlet screens, find a sheet metal screw that will just screw into the top of the old filter without damaging the injector body. Clamp the head of the screw into a vise and screw the injector several turns onto the screw. Rock the injector back and forth slightly while pulling firmly to remove the filter from the injector.
  • Tap new filters in with a very small hammer while holding the injector body firmly in your other hand. Do not place the end of the injector against a solid surface while doing this.
  • Remove pintle caps by popping them off with a utility knife or sidecutters. Again, be cautious to avoid damaging the orifice plate or pintle on the end of the injector.
  • Use a 10mm socket to seat the new pintle cap onto the end of the injector after spacer and o-ring have been installed.
Old Jan 9, 2008 | 05:09 PM
SuperSnake's Avatar
SuperSnake
Is there any name that the kits come under at Ebay or is there a auto parts store that carry them?
Old Jan 9, 2008 | 06:07 PM
subford's Avatar
subford
Here is one on ebay.
http://cgi.ebay.com/ebaymotors/FORD-...spagenameZWDVW
I would think that most Auto Parts Stores could order the kits if they do not carrier them./
Old Jan 9, 2008 | 06:13 PM
SuperSnake's Avatar
SuperSnake
http://cgi.ebay.com/ebaymotors/FORD-PICKUP-F-Series-TRUCK-FUEL-INJECTOR-SEAL-KIT-NEW_W0QQcmdZViewItemQQcategoryZ33553QQihZ001QQitem Z110212412633QQrdZ1QQsspagenameZWDVW
Thank you for the link. where do you get the filters and screen or does it come with the kit?
After reading the instructions you posted it's easier than rebuilding a carb.
Old Jan 9, 2008 | 06:43 PM
subford's Avatar
subford
That links kit does not seem to have the filters and screen.
This is ebay post the instructions were from but that auction is over.
http://cgi.ebay.com/ebaymotors/Fuel-...QQcmdZViewItem
Old Jan 9, 2008 | 07:22 PM
SuperSnake's Avatar
SuperSnake
http://cgi.ebay.com/ebaymotors/Fuel-injector-parts-kit-pintle-caps-o-rings-filters_W0QQitemZ320195305982QQihZ011QQcategoryZ33 554QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I sent a email to the store that sell these kits to see if thet have any more.
Thanks for your help.
Old Jan 9, 2008 | 09:01 PM
SuperSnake's Avatar
SuperSnake
subford,I just ordered my kit.Thank you for your help...
How does your truck run since rebuilding your injectors? Also wjay should I use to clean the inside of the injectors.
Old Jan 9, 2008 | 09:30 PM
subford's Avatar
subford
I did not mean to mislead you.
I was just relaying the information that you were asking for.
I have not had the need to rebuild any injectors yet.
Let us know how this turns out for you.
Old Jan 9, 2008 | 09:59 PM
SuperSnake's Avatar
SuperSnake
I will let everyone know how this turns out
Old Mar 5, 2008 | 07:30 PM
SuperSnake's Avatar
SuperSnake
We got the kit,rebuilt all 8 injectors it only took a hour to do.I'll let you know how it does after getting my engine in.
tpc3
Dec 13, 2013 08:36 PM
danielwd
1983 - 2012 Ranger & B-Series
Jan 2, 2011 10:18 PM
turbill
Dec 22, 2010 06:59 PM
SAltonS
Dec 18, 2009 08:36 PM
Nathan
Aug 5, 2001 08:58 PM
