03' 6.0 rough start
Old Jan 9, 2008 | 09:21 AM
tepp1957's Avatar
tepp1957
03' 6.0 rough start
can anyone share thoughts with very rough running 6.0 when cold. Starts fine idles ok but has to warm up 20 minutes before it wont buck, snort and miss shifts. Once warm it runs like a top....I live in Florida so cold is relative to most. Are the injectors the likely issue?
I appreciate any input.
Old Jan 9, 2008 | 09:59 AM
BLK94F150's Avatar
BLK94F150
I'd say it's probably the injectors. Depending on when it was made, you may have some of your 5 year warranty left if you're not over 100,000 miles.
Also you posted this in the 09 F150 forum. Farther on down there is a forum dedicated to the 6.0 only. This will most likely get moved there.
Mike
Old Jan 9, 2008 | 10:29 AM
rollerstud98's Avatar
rollerstud98
Sounds like injector stiction, mine was doing that so i took it to ford and asked them to give me the latest flash, which is the inductive heating flash on the injectors and this morning it was -16 celcius out and it started up with out any roughness or lack of power without being plugged in
Old Jan 9, 2008 | 03:09 PM
kaboom10's Avatar
kaboom10
First off when did you change the fuel filter? The ECU runs on a loop till the temp sensor gets to a pre set temp. Do you get codes?
Old Jan 9, 2008 | 04:06 PM
rollerstud98
With my 6.0 when the injectors were sticking it'd have the exact same symptoms as his, got the new flash and no longer have any of those problems, his may be to far gone for just the flash to fix though. but you're right to on changing the fuel filter
Old Jan 9, 2008 | 06:58 PM
kaboom10's Avatar
kaboom10
I replace my fuel filter as scheduled and I also use ZMax in the gas. I hope it continues as well as it has. I noticed an increase in performce after its use.
