05 XLT Power window switch question
Old Jan 9, 2008 | 06:21 AM
ASR GUNS's Avatar
ASR GUNS
As stated I have an 05 XLT w\ power windows, I had the kids in back and they were playing with the windows so i locked them, well after I unlocked them the 2 on the pass side will roll down but not up. You have to use the button on the drivers door to roll them up. Any thoughts?
Old Jan 9, 2008 | 12:53 PM
VFR_Man's Avatar
VFR_Man
It's a bit odd for two to act up at the same time, but I would guess it's just the switch on those particular windows. The contacts may just be dirty, so you could try rocking them back and forth like mad with the power off to see if they can clean themselves up. If that doesn't work, the switches aren't terribly expensive or hard to replace.
Old Jan 9, 2008 | 01:56 PM
ASR GUNS's Avatar
ASR GUNS
I will try that. how do I get them out if it doesn't work?
Thanks
Old Jan 10, 2008 | 01:49 PM
VFR_Man's Avatar
VFR_Man
They're usually just clipped into the door panel. If you take the panel off, you should see the clips that you can press on to get them to pop out.
Old Jan 21, 2008 | 03:09 PM
ASR GUNS's Avatar
ASR GUNS
[QUOTE=VFR_Man]They're usually just clipped into the door panel. If you take the panel off, you should see the clips that you can press on to get them to pop out.[/QUOTE/]
How does the arm rest come off?
