HD Headlight Wiring Harness - Help
Old Jan 8, 2008 | 10:45 PM
edsf100's Avatar
edsf100
Anyone install the LMC HD Wiring harness for the HID euro lights? There is a three prong connector to turn on the relays, connecting to the headlight switch I assume for high and low beams. Instructions were not very helpful.
Old Jan 9, 2008 | 09:18 AM
manglass's Avatar
manglass
I have no direct experience with the it but from your description, it sounds as if the 3 prong connector goes to the floor-mounted dimmer switch. That has 3 prongs and would be where you would want to tap for the high and low beams to the relays.
Lou
Old Jan 9, 2008 | 12:12 PM
4tl8ford's Avatar
4tl8ford
Ed
See if these may help.
Old Jan 9, 2008 | 01:12 PM
edsf100's Avatar
edsf100
Excellent! Thanks for the help.
