Sponsored by: Real Truck
Transmission fluid?
Old Jan 8, 2008 | 10:04 PM
wanabe2's Avatar
wanabe2
Transmission fluid?
I went to the Ford dealer today to get some trany fluid for my truck and they said I needed Mercon V. I got 20 quarts so I could flush mine, but I am not sure if this is the correct fluid? Truck is a 03 250 5.4 V8 auto. Thanks!
Old Jan 8, 2008 | 11:30 PM
cartmanea's Avatar
cartmanea
Look in your manual to be sure, but I think that's correct. The Torqshift uses the really spendy stuff, Mercon SP I think.
Old Jan 8, 2008 | 11:43 PM
ken kenmnedy's Avatar
ken kenmnedy
YEA the ford dealer and the parts stores all say that mercronV is all there is gonna be so sooner or later we all gotta do it
Old Jan 9, 2008 | 11:32 AM
wanabe2's Avatar
wanabe2
The owners manual just said to use Mercon. I was just looking over the transmission flush instructions on this site and it said to onlu use Mercon ATF and to not use Mercon V. So what do I use?
Old Jan 9, 2008 | 12:09 PM
Beerstalker's Avatar
Beerstalker
Ford issued a TSB that says to start using Mercon V in all Mercon applications, as they have discontinued Mercon. So go ahead and use the Mercon V that you bought.
I don't have the TSB handy, but if you do a search in this forum you should be able to find it.
Old Jan 9, 2008 | 04:43 PM
wanabe2's Avatar
wanabe2
Thanks for the help. I just got done with the flush and it did help. It seems to shift smoother, and the shutter is gone so far. I should of done this a long time ago, and the truck only has 63,xxx miles on it. Pulling off the return line is the only way to go on this project! Before it I only changed what was in the pan, now I am able to change all of it. Thanks again!
Old Jan 9, 2008 | 05:41 PM
boxcar1974's Avatar
boxcar1974
I have been running Mercon V for 60K miles and no problems. So dont lose any sleep over it. Glad it helped you situation.
