Cam question
Old Jan 8, 2008 | 07:57 PM
wyotecher07's Avatar
wyotecher07
Cam question
Ive got a 289 in my 64 Effe and I want to install a bigger cam. Was curious if anyone knew of any problems I would be facing with binding with such a large lift on the cam with stock bottom end. The Cam specs are Valve Lift with Factory Rocker Arm Ratio: 0.538 int./0.560 exh. lift
Duration: 276 int./284 exh.
Thanks for any help you guys.
Alex
Old Jan 9, 2008 | 12:02 PM
Putt's Avatar
Putt
You would likely have clearance to the pistons, but with that large of a cam you are going to lose a lot of low rpm power. It will not run well unless you have higher compression, 4 barrel intake/carb and headers. The valve springs will need replaced with the cam manufacturers suggested springs to run that much lift, other more involved modifications may be necessary also.
Old Jan 9, 2008 | 05:03 PM
wyotecher07
I understand, the cam is just one of a few top end mods I am doing. I just havent been able to find much about clearences. Thanks for your help.
