Cutting coils
Old Jan 8, 2008 | 07:49 PM
antunez13's Avatar
antunez13
Cutting coils
Is it possible to cut the coils on our trucks it seems like it wouldnt work, but im not sure, i know everybody says not to do it but, you know some of us dont listen i have another lowered truck with all the right parts, this isnt a daily it ]s more for kicks, i want it low and load as hell.
Old Jan 8, 2008 | 07:59 PM
Franklin2's Avatar
Franklin2
Cutting the coils is not the problem. Alignment is. You can't drop it and keep the tires from wearing out. You have to get dropped beams.
Old Jan 8, 2008 | 08:15 PM
antunez13's Avatar
antunez13
can't i get an allighnment and if i did cut the coils, where do i cut? top or bottom ?how many coils for amount of drop, i drive this to work about 4 miles
Old Jan 8, 2008 | 08:34 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Depending on the truck, some later models have a car type suspension (especially Chevy's) with ball joints and full upper and lower control arms and such, if it's I-Beams, best get the wallet out. Besides cutting coils is for ricers or people who want to ride in a trampoline, just my opinion. If you want to lower it, getr dropped beams or spindles, depending on the suspension set up. that way you keep the geometry straight. then of course there is the shocks etc. Grab a copy of sport truck, there are some pretty sweet rides in there. Or go ballz out and bag it. also depending on how low you go you may need to notch the frame and bed, change the exhaust, that kinda stuff.
Old Jan 8, 2008 | 09:05 PM
antunez13's Avatar
antunez13
i was hoping to cut the springs to get a 3' drop and buy a rear flip kit with the c notch, i cant see me being able to spend 600 dollars for the ibeams and flip kit even cuting springs (free) new shocks, flip kit, c notch, still will run up to more than a hundred
antunez13's Avatar
antunez13
antunez13's Avatar
antunez13
Old Jan 8, 2008 | 10:03 PM
RangerPilot's Avatar
RangerPilot
Not wanting to be rude...but cutting the springs to slam it is a half-assed way of doing it, and you're not going to be saving anythign at the rate you're going to burn through front tires.
If you're going to do it, do it right.
Old Jan 8, 2008 | 10:15 PM
Franklin2's Avatar
Franklin2
The problem is, when they align it, they have a limited amount of adjustment. They can try to align it, but they won't be able to get it in. If you go with a very mild 1 inch drop, they may still be able to get it in.
Old Jan 8, 2008 | 10:57 PM
'85 SIX BANGER's Avatar
'85 SIX BANGER
With the I-beams the camber would be so far out, you wouldn't be able to turn it.
/-__-\
Old Jan 9, 2008 | 12:21 PM
mudgepondexpress's Avatar
mudgepondexpress
If you cut the coils (which in itself it OK, cut from the top and do half a coil at a time) it will drop the front but limit your travel. You can cut enough for a decent 1.5 inch drop and still have enough suspension left for a decent ride.
The problem is the chamber adjustment. These years are unadjustable unless you can find someone to bend the beam. Toe in/out will adjust and the caster shouldn't change. My pickup actually wore the tires better when I first lowered it roughly 1.5 inches (tread was flatter, before it wore the outsides horribly). I now have drop beams/shackles and hangers for the 3/4 drop.
Kenny
Old Jan 9, 2008 | 12:52 PM
86F150302's Avatar
86F150302
My truck is pretty low as it is in the front (probably because it needs new shocks) but I want to lower the rear to match it. Where could I get rear suspension parts? Maybe a shackle drop??
Old Jan 9, 2008 | 01:03 PM
mudgepondexpress
Most places handle a shackle drop, ebay, summit, probably sponsors of this site. Shackles alone won't do much, maybe1 inch (they advertise as 2 but you only get 1/2 the benefit since you are only lowering one side of the spring).
I used a Belltech setup in the back of mine. The flip kit was too much for a stock frame and still wanting to use it as a pickup.
Kenny
Old Jan 9, 2008 | 03:52 PM
antunez13's Avatar
antunez13
i was looking at the springs and it looks like the spring on top is curved in and the then bolted down, if i cut it, it dosent look like it would bolt back in like it would be to wide.
Old Jan 9, 2008 | 04:06 PM
mudgepondexpress
Correct, you have to reform the end of the spring to make it work right.
Kenny
