460 or what help please
Old Sep 18, 2002 | 03:15 PM
MOERULES's Avatar
MOERULES
hey guess i just picked up a 79 250 4x4 complete chassie with motor.i was told the motor was a 460 marine engine but im not sure it is even a 460..1st off i cant find any casting numbers on the out side of the head but 45 on each side near the bottom corner.inside i found the #5l22and the #53197cast in a circle.the # under the starter are D9TE-AB.on the intake are the # OSTE-942??A and 3E23.please help i am not sure what i even have bought!!!!!!!!!!!!!!!:-staun
Old Sep 18, 2002 | 07:18 PM
Big F250's Avatar
Big F250
The D9TE-AB block is a 79 460 truck block, likely the stock engine that came with the truck. I dont know where the marine came from. The casting number for the heads is under the bottom rail of the valve covers. Take the valve covers off and you'll most likely find D3VE-A2A castings, maybe D8VE.
Old Sep 19, 2002 | 12:35 PM
dpoelstra's Avatar
dpoelstra
If you remove the valve covers, note the size of the valve stems. If they are normal valves, it is stock. If they are really fat, they may be sodium filled valves used in marine engines. These are really good valves, and run cool so they rarely burn. Expensive too.
Old Sep 19, 2002 | 06:15 PM
Kenworth's Avatar
Kenworth
If this is a marine'd 460 it will have either stainless or brass freeze plugs the engine may even have stainless bolts attaching some parts. It would be pretty rare someone would have put a marine'd 460 into the truck you have.
Old Sep 19, 2002 | 06:42 PM
Brian460's Avatar
Brian460
>D8VE.
The 460 was not put into a 4x4 until 1983, not saying somebody else didn't swap one in though.
No need to take off the valve covers the casting number is between the inside two spark plugs.:-)
Old Sep 19, 2002 | 08:08 PM
MOERULES's Avatar
MOERULES
hey thanks for the insight...i took the valve covers off cleaned up inside and out on the head and still cant find any # other than 5L22.the guy i bought it from told me the heads were marine heads if they even exist i dont know!
Old Sep 19, 2002 | 10:03 PM
Mil1ion's Avatar
Mil1ion
They were cast November 22/1975 (or 85) I suspect Unless you find the other casting number near the exhaust ports just under the valve cover lip.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Sep 19, 2002 | 10:24 PM
qtrmiler's Avatar
qtrmiler
2 things. Sodium valves were not used in 385 series engines as they all have 11/32" valve stems. Also, I guess someone forgot to tell Ford they put a 460 in the '79 F-250 $x$ I bought new. Mmmmmmmm strange.
Old Sep 19, 2002 | 10:51 PM
dpoelstra's Avatar
dpoelstra
Oh, sorry about the sodium thing, I am thinking of the other guys...I assumed that Ford used them too.
Old Sep 22, 2002 | 10:26 AM
qtrmiler's Avatar
qtrmiler
Ford did use them on FE applications. I killed a really good 427 side oiler because of them once.
Old Sep 22, 2002 | 11:29 AM
georgedavila's Avatar
georgedavila
crazed87bronco
Feb 11, 2011 08:48 AM
gliderdad
Mar 27, 2009 11:40 PM
JBravo
Oct 22, 2008 05:25 PM
straightsix4x4
19
Jun 29, 2008 11:10 PM
glanzer_51
Jun 11, 2007 12:59 AM
