Four gear timing set?
Old Jan 8, 2008 | 03:16 PM
Mike DeRosia's Avatar
Mike DeRosia
I'm planning to remove a 460 from a donor and install it in my 76 f100 and thought I would change the timing gears at that time.
I know there's timing sets on the market that use "idler gears" instead of a chain. Is there any advantage to this in a bone stock set up?
Old Jan 8, 2008 | 07:45 PM
BChance's Avatar
BChance
noise. Gear drives whine kind of like a blower. Other than that... no.
Old Jan 8, 2008 | 11:45 PM
monsterbaby's Avatar
monsterbaby
some claim that the gear drivers are actually worse then gears, and if you check many are actually rpm limited and the dog bone style is the worst, although the easiest to install.
Old Jan 9, 2008 | 07:51 AM
Mike DeRosia
Thanks, guys. You made up my mind.
