Alternate bellhousing???
Old Jul 2, 2002 | 08:46 PM
JETHRO351's Avatar
JETHRO351
I ran across a 1977 460 today that had a definitive second bell-housing bolt pattern. I thought I had seen a chrysler 727 bolted to a 460 in a junkyard before, but, I had told myself that I was hallucinating due to the heat. Nevertheless, this block had drilled and tapped holes in this second bellhousing. What's the deal with this? Anyone else ever ran into this? Am deadly curious.
Old Jul 4, 2002 | 10:33 PM
WC76TX's Avatar
WC76TX
was it a 460 to sae #1 bell adapter for a medium duty truck? if so the second pattern should be almost round(like 390 only larger), and have mounting holes in each side. unless you are talking about more holes in the block itself!
Old Jul 4, 2002 | 11:45 PM
merc460's Avatar
merc460
Like WC76XT was saying its probably from a medium duty truck and the transmision if it was an automatic is possibly a allison transmission ford used this adapter to adapt the 370/ 429/ 460 to the Allison transmision, it should also have pads on the sides to mount it to the frame and the Allison uses a full circle bolt pattern Eric
Old Sep 28, 2002 | 08:45 PM
elliott's Avatar
elliott
What years did Ford put 460's in MD trucks? Thank, Elliott
Old Sep 29, 2002 | 09:33 PM
nebesis's Avatar
nebesis
lincoln bell housing had an offset bell housing bolt. The blocks were taped for both of them.
Old Sep 29, 2002 | 09:36 PM
lvmoose007's Avatar
lvmoose007
