Machine work on 6.9 heads??
I Recently purchased two trucks.
A 1986 F350 crewcab 4x4 with the non turbo 6.9 and the C-6 transmission.
A 1986 F250 regular cab 4x4 with the non turbo 6.9 (thrown rod through the pan...ouch) and the C-6 transmission.
My questions are related to the regular cab truck which recently had the heads rebuilt. The previous owner stated that the valves were done and the heads were milled. From my experience working on gasoline engines, this could increase the compression slightly. Would it have an inherent bad affect on the deisel which is already at 20 to 1 or better compression? Could this have caused the engine to throw the rod? I purchased the truck with the thrown rod.
How can you tell if you have a lower end knock? My crew is very loud to begin with, let alone trying to hear a knock in the lower end.
Any help would be appreciated.
Thanks
Minimum head thickness (from "deck" to valve cover surface): 4.7950"
If you need more let me know.
Thankyou for the information. I'm picking up the truck this weekend. It might be a few weeks before I can check the head thickness, but at least you have given me an idea to measure. If the heads are under the minimum...are they trash??
I did come across a 7.3 block, possibly even the whole shortblock for 200 bucks. Can 6.9 heads, intake, etc... be adapted for a 7.3? I realize the 7.3 uses larger head bolts, but can the 6.9 head holes be opened up to work? I live by the motto..... "No replacement for cubic displacement". And.... why should I build a 6.9, when I can build a 7.3 for nearly the same cost? Especially if I can use most of the 6.9 external parts on the 7.3.
Thanks again..
But the 6.9 block will last longer due to thicker cylinder walls.
Welcome to FTE and the IDI diesel forum.
The bottom of the heads are flat, no combustion chamber like you would have on a gasser.
If the heads are to thin, the valves and pistons try to occupy the same space at the same time.
Not a good thing.
The clearance between the head and piston top is the thickness of the head gasket.
The 7.3 has cavitation issues that the 6.9 does not have.
You can do a minimal bore on a 6.9 to straighten out the cylinder walls, you are asking for trouble boring a 7.3 block.
Head studs are the way to go when rebuilding a 6.9.
I also will not have to rebore my 6.9, since the wear is so little, just some honing.
