Been a while since I have been on the site. Looks better than before. Anyway, here's what I've got; When I shift from Drive into reverse the radio will shut off. Now, I can shift into reverse from any other gear and everything is fine, it only happens going from drive to reverse. I have a 1999 Expy EB with about 190,800 miles. Anyone familiar with this or any other like occurrence?
Same problem The od light finally started to flash so I had the coeds pulled.
The culprit was the PRND switch appaentlry it was shorting out in reverse and messin withe the computer. Changed it less than 10 min.
