vibration,shake,chatter
I've been doing alot of home work and searching on this site for anwers to my vibration, shake, chatter problem(more specfics later). There are many posts about it but no real answer to the problems that people are having. I hope or think I can help with the experiences I have gone through, first off my vibration in perticular.
I would be crusing in my truck in 2WD I'd get a slight vibration at 48-55 then 60 then 80. I was getting the vibration in the floor pan,some what in the steering wheel nothing crazy though,(basicly you knew it was there but you could live with it). When I would put it in 4WD you know when your going 50,60 then 80 because the steering wheel, floor pan, dash, the whole front end would vibrate vilantly.
Now lets consentrate on some other problems I have, rough starting(would make it seem as if the IAC was acting up), there was a slight ping or fluter you'd hear(some people would call it a putter). When the truck was running, I thought it was the headers making the noise because there are some studs missing (makes sence right?
)So I took it to a place called C.T. Cam, they speacailize in driveterrian, well to tell you the truth thats all they do. Took it in early in the morning told them my porblems and when I experience them. I have no idea what the call the procegure but it involved jacking the truck off the floor completely and straping it down, so they went to the speeds I said were problem area's in 2WD, He said the drive shaft in the rear was showing some movement at 80klm's/hr but 40kl-60kl should no sign's of problems I was explainning, did the exact same thing in 4WD with the same results. (I told my self, well F... that ain't possible it was doing it while I was driving here.)
So we went out for a ride, the symptoms that I had explained to them earlyer had magicly reapeared 40kl-60kl but at 80kl the slight vibration was fixed
. It just so happens that my truck's problem was so speacail they called in the old timer in the shop,turns out he's a pro drag car builder/engine tunning(
who'd a thought?) he gets in my truck, rough starts, notices the putter, pulls on the hood latch gets out the truck. Opens the hood listens closely then walks towards the tail pipes, listens for a bit then gets back in the truck. Says my engine's missing, garunteed 1 dead cylinder possibly 2. So we head out on the highway hit 45-60 klms in 2WD he notes the slight vibration, then puts it in 4WD(the violance begins
). we head back to C.T he connects a 5000lb trailer to my truck, he claims the violant vibration,shake,chatter is caused by the engine under load (4WD puts load on your engine) and if I'am right it will do the same in 2WD with the trailer attached, sure enough it did.Can I say its the dead cylinders? and there the cause of my vibratting problems? Not yet, that's 2 months from now, but I'am sure as hell going to let you guys know.
Hope this gives some light or step in the right direction with your trucks problem as well
Regards
Skoda
P.S some guys are probably wondering why its in the V10 section, well my baby's a V10
biz
biz
Haven't figured out which cylinders yet, the reason for having to wait 2 months is I gotta save up some cash to have the problem fixed. I mean 2 months by I'll have a deffinate answer for you guys by then.
biz
ordered 2 COP's, bummer is it's going to take 3 weeks to get here. . .
http://www.motorcraftservice.com/vdi...250+Super+Duty
There you will find the "Service Engine Soon" on page 8. It is found just under the Tach...and should light up everytime you start your SD. When you turn the ignition to the "ON" position (which is right before the "start"). This is a test for all the bulbs on the instrument cluster.
Talking about percentages...it is per cylinder or mis-fire. If you have two dead cylinders due to COP failures, that is a 100% failure per cylinder. The "Service Engine Soon" should have triggered...or may even blink.
Hope this helps...
biz
also checked up that dtc you were talking about, doesn't look like I have one... That possible? No I haven't checked it with a obd2 scanner.
LOL.
Just a little clarification...
biz
also checked up that dtc you were talking about, doesn't look like I have one... That possible? No I haven't checked it with a obd2 scanner.True story...I have a friend that bought a 2002 car...and was having issues with the engine. Turns out...that the PCM was recording fault codes, but did not light up the indicator on the dash. Reason...was that the previous owner (or someone) removed the bulb all together. Errr!!!
Luckily...that is why they light up before start to determine if the bulb is bad.Good luck...
biz
