I am due for my first oil change on my 04 F250 Super Duty 6.0 Torbo. What do you gus recommend for Oil and filter? I used to work on Tractors and we used Rotella T 15/40, anything else out there a better bang for the buck??
I am ordering a brass drain pan valve from dieselsite.com to make future oil changes easier.
What can I do with my EGR to clean it up before I unplug it and bypass it? Is there nay diresctions or specifics??
There is a lot of info in the tech folder. Check here 6.0L Diesel: ..................Tech Folder.............. If you are new to the 6.0 there is lots of info here. I have learned a lot. Instructions for just about anything you need to do.
