Shaking
Old Jan 6, 2008 | 10:33 PM
MIKE1646's Avatar
MIKE1646
Shaking
I was doing around 35 mph on my truck today on a road was going to be resurfaced, when the truck hit the new asphalt wich was a little higher, the steering wheel started shaking so bad that I had to slow down to 20 to stop it.
Any ideas? Truck has 18k miles.
Old Jan 6, 2008 | 11:28 PM
bismic's Avatar
bismic
This TSB may apply:
Steering Wheel Shimmy After Riding Over Bumps/Ruts:
Some 05 and 07 F-Series trucks may exhibit an oscillation/shimmy in the steering wheel after hitting bumps or ruts in the road. Typical steering wheel movement is 5 degrees and usually smooths out after about 5 oscillations. This condition is more prevalent on 4X4 trucks with steering wheels that have radio and climate controls. The truck will need to be inspected: tire pressure checked; steering damper inspected (replace with 5C3Z-3E651-D if needed); all suspension and steering fasteners torqued; steering checked for binding; steering gear adjustment checked/adjusted. The caster may need to be reduced by 0.5-0.75 degrees. After this, trucks build prior to 10-8-04 should have the steering wheel replaced.
Old Jan 7, 2008 | 06:35 PM
Joms's Avatar
Joms
Search for the all famous 'Death Wobbel'. You should find a lot of information...
