well, i thought i had the thing runnin...nope sure isnt. fuel pressure is at 6 psi, ran fine for bout 10 min, then started stallin out. then wouldnt crank back up. then would, but would only run for a few sec then die again, even if i had my foot in it. this is getting really aggravating.....i cant afford to keep towin this thing around
check all this
fuel filter , gas lines, gas pickup @ the tank, make sure no stuck carb needle, wires to coil, REPLACE MODULE there like 15 bucks and is the problem MOST of the time
i have gone through alot in my day of fords
5 ford machines very one of them had the module replaced atleast once when i had them
