1978 - 1996 Big Bronco
Ignition Switch help....
Old Jan 7, 2008 | 03:30 PM
mikeberman04's Avatar
mikeberman04
I have to replace the ignition switch in my '88 bronco, has anyone ever done this before and could help guide me thro it? thanks!
Old Jan 8, 2008 | 10:49 PM
mrknight01's Avatar
mrknight01
Thumbs up Ignition Switch Replacement
  1. Disconnect the negative battery cable.
  2. Remove the steering column shroud and lower the steering column.
  3. Disconnect the ignition switch electrical harness connector.
  4. Remove the 2 nuts retaining the ignition switch to the steering column housing.
  5. Lift the ignition switch upward to disengage the actuator rod from the switch and remove the switch.
To install:
When installing the ignition switch, both the locking mechanism at the top of the column and the switch itself must be in the LOCK position for correct adjustment. To hold the mechanical parts of the column in the LOCK position, move the shift lever into PARK (with automatic transmissions) or REVERSE (with manual transmissions), turn the key to the LOCK position, and remove the key. New replacement switches, when received, are already pinned in the LOCK position by a metal shipping pin inserted in a locking hole on the side of the switch.
  1. Engage the actuator rod in the ignition switch.
  2. Place the ignition switch on the steering column housing and loosely install the 2 retaining nuts.
  3. Move the switch up or down along the column to locate the mid-position of the actuator rod lash, then tighten the retaining nuts to 47-64 inch lbs. (5-7 Nm).
  4. Raise the steering column into position at instrument panel. Install steering column shroud.
  5. Connect the negative battery cable.
  6. Remove the locking pin, connect the negative battery cable, and verify that the engine will only crank in PARK and NEUTRAL. Also check to make certain that the start circuit cannot be actuated in the DRIVE and REVERSE positions.
Chefsteele
25
Jan 20, 2014 10:46 AM
ahurt1973
Oct 25, 2006 02:52 PM
orangedbowl
May 10, 2005 11:09 PM
