Front Differential Servicing
Old Jan 7, 2008 | 12:28 PM
PSDLOVER's Avatar
PSDLOVER
I know this has been discussed but how important or how often do you FWD drivers mess with the front diff. My rear has been changed twice already. The second time I installed the new alum. diff cover and filled with Royal Purple which I learned of here and am sure will be good for quite some time. Last change I used Chevron and it was brown and smelly, burned up looking and beginning to leak thru. I do not recommend that. Should the front diff cover also be replaced and is the service interval and oil the same? Its not as easy to get a wrench on though.
Old Jan 7, 2008 | 12:34 PM
Izzy351's Avatar
Izzy351
I have a 2wd, but here's guzzle's write up on the front diff:
http://guzzle.rbmicro.com/fdiff.html
