Sponsored by: Real Truck
??HOW do you remove the foglights
Old Jan 7, 2008 | 12:52 AM
rg200amp's Avatar
rg200amp
Smile ??HOW do you remove the foglights
whats up guys, i want to remove my foglights and put new ones in, my stock ones are cracked and dirty
do i need to take the bumper off? it looks hard.
you guys have any info?
THANKS GUYS
Old Jan 7, 2008 | 01:03 AM
GregsSD's Avatar
GregsSD
I've taken mine out by removing the license plate, then you can reach in and get to the bolts, but it is a tight squeeze.
Old Jan 7, 2008 | 08:43 AM
sofdchief's Avatar
sofdchief
My sugestion? just take the bumper off. It's a lot easier than it looks. There are 4 large bolts (2 at each tow hook), and two small bolts (one at each lower corner, inside wheel well). Once the bumper is off, turn it over and remove/replace your foglights...simple as that. i have had my bumpers off many times, and it's really quite simple.
Old Jan 7, 2008 | 08:46 AM
Matt M, PA's Avatar
Matt M, PA
I installed fogs in my '05 Ex and left the bumper on.
I simply reached in and removed the bolts that hold the brackets to the bumper...then removed the pin that held the light to the bracket. At least on an '05, the lights do not fit through the opening. I may have had to also remove the adjusting screw...but you' ll need to adjust them anyhow before driving. It's easy to reach into the opening to put them together/take them apart. And...one person can do it.
Old Jan 7, 2008 | 01:33 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Light with brackets don't fit out the hole so remove the bumper. As stated it is very easy and can be done as an easy one man operation, done mine several times.
Old Jan 8, 2008 | 08:25 PM
mackda600's Avatar
mackda600
take the bumper off, i've put 4 bumpers on my truck. very easy.
Old Jan 8, 2008 | 08:27 PM
greythorn3's Avatar
greythorn3
THANKS GUYS
use a hammer that will remove them!
Ray
