Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
#4 Miss Fire
Old Jan 6, 2008 | 05:46 PM
5_labsownus's Avatar
5_labsownus
#4 Miss Fire
Today the engine light started to flash. I hooked the computer to it and came up with #4 miss fire. Well I have never changed plugs in an escape.
I aSSume it is like other 3.0s and the intake needs to come off to replace the plugs.
2002 V6 4wd
Anyone shed some light on this!
Rod
Old Jan 11, 2008 | 11:10 PM
5_labsownus
Well it turned out to be the coil on #4. But I replaced the plugs and boots while I was there because the vehicle has 130K at the time.
The plugs and boots were not as bad as other V6s. I took me longer to change the oil the plugs.
Yes, I had to pull the upper intake and that was pretty painless and gave you very good access to the plugs.
I did learn one thing, the intake gaskes are "reusable" HAHA! For $8.00 buy new ones and save youself some trouble.
Rod
Old Jan 12, 2008 | 05:09 PM
Wilber15's Avatar
Wilber15
I don't do plugs on those engines without quoting gaskets too. If the customer opts to go without new gaskets, I make it clear that if a problem develops after the repair, I never wanna see it in my stall because I had it on the quote to replace them.
Old Jan 13, 2008 | 06:50 PM
OhioMedic1416's Avatar
OhioMedic1416
Problems Starting
Rod
Did you have any trouble starting the escape when this was going on? If not, did it start, then get rough, idle down and die?
Old Jan 15, 2008 | 08:33 PM
5_labsownus
It started just fine but idled rough for a few seconds and smoothed out. At highway speeds it ran fine would jerk once and a while. After about 20 miles the light stayed on and it must drop that cylender in the computer it ran good.
Old Feb 12, 2008 | 09:21 PM
rickfar's Avatar
rickfar
well where do you get the o rings for 8.00 as my dealer quoted me 5.30 each and it is my understanding you need 6 when you change plugs. is there after market intake o rings? im newbie just bought a 06 with 92000 and want to change the plugs first off
Old Feb 14, 2008 | 03:52 PM
Wilber15's Avatar
Wilber15
It should come as an intake kit.
Also, I'm willing to bet you have an injector going bad. Are you still getting that "early" start rough idle, then as the motor warms up it smooths out? We've been having problems with injectors in the 5.4L 3V engines doing that on cold start.
Old Feb 14, 2008 | 06:06 PM
5_labsownus
Autozone had the intake seals (all 6) from Felpro in one package and they looked like the OEM!
stuemany
Feb 19, 2013 05:34 PM
maverick_43
2004 - 2008 F150
Jan 29, 2012 11:07 AM
blueovalmann
2004 - 2008 F150
May 7, 2011 11:07 AM
switchback
Modular V8 (4.6L, 5.4L)
Sep 26, 2003 11:26 AM
