460 Manuel choke conversion
Old Jan 6, 2008 | 01:04 PM
David Johnsen's Avatar
David Johnsen
1986 250 with 460 automatic 2 wheel drive. I think the carb is the 4180. The electric choke has never operated properly. I have re-adjusted it a few times and cleaned it which worked for awhile. Then it would hang up. Nothing seems binding. I have removed most of the smog stuff, smog pumps, etc. It run great when it warms up. and I prop the choke plate wide open.
My question is: Will the Holley conversion kit # 45-225 fit? I would like to change to a manuel choke. They only list for the 4160, but they look the same.
Also will the fast idle cam work after the conversion?
Autozone price seems reasonable at 28 bucks for the kit. The cable and cable mounting bracket seem overpriced but I can probably use a generic for those.
TIA
Old Jan 6, 2008 | 01:25 PM
Fomoko1's Avatar
Fomoko1
Hi and welcome David.
Drop into the Fuel Injection, Carburetion and Fuel System forum: https://www.ford-trucks.com/forums/forum72/ and also the 1980 - 1986 F100, F150 And Larger F-Series Trucks forum: https://www.ford-trucks.com/forums/forum37/
Don`t forget to post your intro in your local OR chapter: https://www.ford-trucks.com/forums/forum190/
squibb
New Member Introductions
Jan 31, 2009 12:24 AM
okie ford
Dec 2, 2007 09:36 PM
NELSON30213
Dec 2, 2007 06:53 PM
dustman600
Feb 11, 2001 04:03 PM
