6637 mod Caution
Old Jan 6, 2008 | 11:25 AM
dieseloholic's Avatar
dieseloholic
Exclamation 6637 mod Caution
This is primarily for anyone who hasn't done this yet. My local service guy and diesel tech just told me about a turbo failure they worked on. Both of these guys have 7.3s and both have the 6637 mod. The guy whoes turbo failed had done the mod, but hadn't gotten the 6637 filter. It looked the same, but it had some internal rings (it was designed to have a pipe slide up inside it). He installed it, fired up the truck and sucked those rings loose and into the turbo and well... I think you can guess the rest. I just thought I'd pass this along as a caution so anyone who hasn't done it yet knows to check.
Old Jan 6, 2008 | 11:35 AM
ron's power stroke's Avatar
ron's power stroke
thats good info to know Mike..thanks for spreading the word...
Old Jan 6, 2008 | 11:52 AM
8tsixt's Avatar
8tsixt
What brand was he using?
Old Jan 6, 2008 | 11:57 AM
TurtleRacing's Avatar
TurtleRacing
PSD Addict
I'm a little lost, are you saying he got a filter that was similar to 6637 but wasn't an actual 6637?
Old Jan 6, 2008 | 02:30 PM
dieseloholic
The tech didn't tell me what the part number was for the filter that caused the problem. He said it looked like the 6637 (he has one on his own truck), but had internal "rings" that would have gone around a tube and those rings are what detached from the inside of the filter an sucked into the turbo.
Old Jan 6, 2008 | 02:34 PM
TurtleRacing
PSD Addict
Well, now everyone knows what to watch for, Thanks.
Old Jan 12, 2008 | 03:43 PM
h2guy's Avatar
h2guy
Well, they always told me that a 7.3 was a "big sucker".
Old Jan 12, 2008 | 03:52 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I wonder if the guys thought they had the 6637, but the parts store gave them the wrong ones. Guess we need to look inside the filters when we buy a new one for the rings. I would think it would be easy to notice.
Good info Mike.
Old Jan 12, 2008 | 07:12 PM
Izzy351's Avatar
Izzy351
Some of these filters go on vehicles with a second fine filter inside it. I'll bet that has something to do with it. Here is a similar one for a Bobcat -- it has another filter that looks something like a roll of string wrapped on a paper towel cylinder this one slides over (wish I had a pic of it!):
Old Jan 12, 2008 | 09:13 PM
dieseloholic
You may be right Joe. He (the service guy) said the filter had "rings" inside it that would have fit over a tube (or like you said an internal filter).
Old Jan 12, 2008 | 11:24 PM
RogueSpear2023's Avatar
RogueSpear2023
All I know is my 6637 is better than a K&N any day
Old Jan 12, 2008 | 11:40 PM
ron01sd's Avatar
ron01sd
i know the 6637 dont have rings, dont know about the same filter but differant part #'s from diff manufactures. i'll stick with the 6637.
Old Jan 12, 2008 | 11:50 PM
dieseloholic
Max, Ron... you might be misunderstanding my post. It's not a caution against doing the mod (notice my signature), but to make sure that you definately get the 6637. This guy apparently either thought he'd gotten the 6637 or went cheaper and got something he thought would work. In either case it went bad for him. I just wanted anyone who hadn't done it yet to make sure they got the 6637 (not something else) so they wouldn't have any problems.
Old Jan 12, 2008 | 11:55 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Good to know
Old Jan 13, 2008 | 01:37 AM
a-rod's Avatar
a-rod
Thanks for sharing! especially since Im about to do the 6637 mod.
