Overhead CB Install Project
Old Jan 6, 2008 | 10:15 AM
nuwave's Avatar
nuwave
I am sure I have read someone here found a simple,clean way to install a CB radio on the interior roof. I have done some searching, but can not find the thread. Ring any bells?
Other ideas for mounting locations would be welcome, although underdash is out of the question.
Old Jan 6, 2008 | 10:23 AM
TheBlueMule's Avatar
TheBlueMule
There is a headliner with a sound system (4 speakers in the rear of headliner) and a mount in front for your radio or I have seen a CB put in there. They have them at broncograveyard.com I am getting one for my truck as soon as I finish the major parts of the resto.
TheBlueMule
Old Jan 6, 2008 | 11:29 AM
77f150got_sand's Avatar
77f150got_sand
I mounted mine in the center hanging down from the roof, I removed the headliner screwed the mount to the center support of the roof then cut two slits in the headliner for the mount to protrude through, I ran all the wiring up the door pillars and hid it behind the door seals and under the headliner, once the headliner was reinstalled I bolted in the CB and hooked up the wires. I mounted a remote speaker back by the dome light and ran a PA under the hood, I mounted the mic directly to the CB. Its a super clean look and works great.
Old Jan 6, 2008 | 11:41 AM
73f100shortbed's Avatar
73f100shortbed
77f150, do you have pictures of that?
Old Jan 6, 2008 | 12:08 PM
77f150got_sand
I snapped a couple pics and made a new album in my gallery with pics of the CB.
Old Jan 6, 2008 | 05:13 PM
nuwave's Avatar
nuwave
Thanks for the pics. This is what I was looking for. You can get the wires down the inside of the pilar, as I learned when I put roof lights on. Note I am installing a 23 channel setup. Remember those? Gotta stay old school!
Old Jan 6, 2008 | 07:11 PM
73f100shortbed
That looks good
Old Jan 6, 2008 | 08:47 PM
77f150got_sand
Thanks for the compliment 73f100! When I restore it I will run the wiring inside the pillar like nuwave suggested, instead of under the door seals, didn't know that could be done, great idea!
