Removing EGR plate?
Old Oct 23, 2002 | 01:56 PM
dpoelstra's Avatar
dpoelstra
Removing EGR plate?
Old Oct 24, 2002 | 09:59 AM
mchild's Avatar
mchild
Removing EGR plate?
I have an `85 F350 with 460 engine. I have removed or disconnected all emission devices including the air pumps. It does not have a cat.
I have just purchased an Edelbrock 1406 (600 cfm) and had anticipated that in the process of installing the new carb that I would remove the EGR plate that is sandwiched between the intake manifold and the carb. I was going to install a standard spacer in place of the EGR plate but, I find the spacer will not cover the exhaust port that provides the EGR with exhaust gases. That port extends out past the standard base of the carb so it would be open, exposed, and leaking exhaust gases if the carb (or spacer) is installed directly on the manifold.
What options are available for removing the EGR plate and retaining the stock manifold?
Thanks,
Mark
Old Oct 24, 2002 | 11:57 AM
LxMan1's Avatar
LxMan1
Removing EGR plate?
Fill in the holes with JB Weld.
Old Oct 25, 2002 | 08:31 PM
82F100SWB's Avatar
82F100SWB
Removing EGR plate?
I drove a bolt in mine and welded it in place... JB Weld would likley do the trick too.
Evan
86 F250 HD XLT Lariat Explorer 4x4 ex. Extended Cab: 460/T19(syncroed granny low)/BW 1345/3.55 geared Full Floater 10.25 and Dana 50 TTB/ 265/75R16 Hankook FR04's on 16x8 Whitespokes(street tires... Need mudders)
78 F150, 351M/C6, eventually to be repowered with a 400
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
