Aerostar Ford Aerostar
Hello!
Old Jan 6, 2008 | 04:10 AM
SKaero's Avatar
SKaero
Post Hello!
Hi everyone what a great forum, And boy do I need one because I have got one hell of a project! I now have 2 Aerostar a 1992 EB AWD, and a 1993 XLT AWD. I have had the 1992 one for 12 year but I got my new 1993 about 2 months ago. My 1992 aero is in good condition but but 1993 is down for the count. First it need a new transhipon and tranfercase, and new front end suspension. But I have a some questions first, hop you can help!
1. How can you stop the leak from the driver side passenger window, does anybody know how to do this?
2. Does any body know were you can get a good transition for an aero 4WD?
3. Also how do you get the sliding door open its stuck and the out side handle is broken, and the inside one does not chash.
Thanks
-SKaero
Old Jan 6, 2008 | 04:56 AM
Pablo-UA's Avatar
Pablo-UA
_________________________________
Easily! With silicone sealant. Cleane all before work (I did it with alcohol) and pyt silicone inside. Not too much.
Remove door trim/cover from inside the van (unscrue small screws with philips screw driver), ypu will see all the locking mechanics inside. I think you will easily find a sourse of troubles. I had door locking motor stuck closed. Used WD-40 to make it working.
Old Jan 6, 2008 | 05:51 AM
SKaero's Avatar
SKaero
Thanks for the reply but I don't think I can use silicone sealant, the vans parked out side and I think it would get to cold/wet to work.
Old Jan 6, 2008 | 09:23 AM
Bear River's Avatar
Bear River
Former ******
You can use WD-40 as a cleaner, but use white lithium grease as a lubricant. WD40 is too thin and doesn't lubricate properly and it attracts dirt.
As far as sealing the window goes, silicone sealant is the only way to go, so you may have to wait till the weather will let you, or till you can keep it inside long enough for the silicone to cure.
As far as the tranny goes, why not rebuild it. The problem with swapping trannies from another vehicle is you have no idea what condition it is in. However, you can easily find out what is wrong with yours. You say the tranny is shot, what does it do? If you aren't afraid of it, you can rebuild it yourself. Just requires the ability to remove the trans from the vehicle. You should get a manual on the A4LD before attempting this.
Old Jan 6, 2008 | 10:17 AM
marty600's Avatar
marty600
My window did that, the above posts are correct, use silicone.
I did NOT and regretted it - i employed a water based homeowner grade window caulk,
and it did seal properly, but it left stains on the paint, they would not even rub out.
It did rain the very next day, i think that was the reason, slow dry time allowed a little to wash out. I did take the window off, it's easy, a handfull of nuts and you're done.
That allows you to do it correctly.
Clean off the butyl before silicone, or buy some butyl and do it like the factory did.
Old Jan 6, 2008 | 11:14 AM
copper_90680's Avatar
copper_90680
Hi SKAero
Welcome to our FTE forum
Old Jan 6, 2008 | 05:26 PM
xlt4wd90's Avatar
xlt4wd90
The quick and dirty way to fix the leak is to use silicone sealant to cover the gap between the window molding and the body, after proper cleaning with wax and silicone remover.
To properly fix the leak would be a pretty big job; you have to remove the window, clean out the old sealant, and apply new sealant. This requires removing all the inside panels from behind the driver's seat.
The factory uses a butyl rubber sealant that never sets. So if it's hot enough, it will get soft and possibly flow away from its surfaces, and if it's cold enough, it will get hard and brittle.
There is a liquid form of butyl rubber sealant that you can get from most auto parts stores. If you can pry the molding enough to stick the nozzle in, you can apply the new sealant underneath. This can make the repair invisible and it will help avoid getting sealant onto the paintwork. However, you still need to warm up the molding to get it soft enough to work with, and try not to stress the glass in the process.
Old Jan 6, 2008 | 08:00 PM
SKaero's Avatar
SKaero
Hi everyone,
Thanks for your reply's, I think I just wait till spring/summer a pull apart the interior and fix it. Still need a transmission. Also does anyone know how to disconnected the starter so I can do a competition test?
Old Jan 6, 2008 | 08:18 PM
93nighthawk's Avatar
93nighthawk
Welcome!
Originally Posted by SKaero
Hi everyone,
As has been suggested, look into rebuilding your tranny yourself or have it profesionally rebuilt. If you pick up a used one, you are looking at getting into trouble. You don't know the history, and it will probably need rebuilt also.
As for the compression check (I believe that is what you are asking info about.) You do not disconect the starter, that is how you perform the test. (The starter rotates the pistons.) What you need to do is disconect the DIS or unplug the Crank Position sensor. Then you would have no spark.
Old Jan 6, 2008 | 08:24 PM
SKaero's Avatar
SKaero
Sorry thats what I meant, So how do you disconnect the DIS or unplug the Crank Position sensor.
Old Jan 6, 2008 | 09:07 PM
93nighthawk
The crank sensor is right behind the crank pully. Just look for a wire going straight down under the water pump. As for the DIS, I am the location of it has left my brain momentarily, but all you need to do is unplug it, and it will not fire the plugs/injectors.
EDIT: The DIS Module is either located:
<TABLE cellSpacing=0 cellPadding=0 width=555 border=0><TBODY><TR><TD>Under hood, driver side, rear engine area, driver side of master cylinder, mounted on firewall</TD></TR></TBODY></TABLE>
or
Under hood, passenger side, upper engine area, rear of air filter housing, mounted on fenderwell
Can't remember which position, and it is too dark right now to look.
Old Jan 8, 2008 | 12:37 AM
Pablo-UA's Avatar
Pablo-UA
Swaping of A4LDs is not a problem usually, but pay attention on solenoids. Early A4LD has no solenoids, in 1987 1 solenoid for TC lock up appeared, from 1988 A4LD has 2 solenoids - first for Lock UP, other for OD clutch.
In '90-s in France appeared strange tranny called A4LDE with 4 solenoids (electronically controlled 1-2-3 shifting and OD, there is no governor in this tranny), later this tranny was improved and calles 4R44E, and later 5R55E was made on base of A4LD too.
Internal parts are similar, like TC, gears, shafts, but valve blocks, channels inside body are different.
