Rear Main Seal
Old Oct 14, 2002 | 12:51 AM
priley's Avatar
priley
Rear Main Seal
All;
I have an '88 F250 460 C-6 4x4. Have a leaking rear main seal, and am getting tired of it leaking like a Ch**y. How much work is it to replace it?
Thanks, Paul
Old Oct 14, 2002 | 01:42 AM
vkaro45's Avatar
vkaro45
Rear Main Seal
I'm looking to do the same thing on my '87. According to the manual you nearly have to pull the engine to get the oil pan off. Once you get the pan off you need to loosen the main caps and remove the rear main, replace the seal and put it all back together. I had a shop quote me $400.00 to do the job. Tempting...
Rodger
Old Oct 14, 2002 | 07:45 PM
FORDNUTTZ's Avatar
FORDNUTTZ
Rear Main Seal
might as well freshin it up when you have it out and apart
put you some new barings and new rings
relap your valves
put new vale steem seals in
Old Oct 23, 2002 | 02:14 PM
dpoelstra's Avatar
dpoelstra
Rear Main Seal
Here is something to consider. I bought an 86 F350 w/460 and it leaked like crazy. It also pushed oil up through the dipstick tube and blew it everywhere. Because of that, I replaced the PCV valve and Viola! The rear main seal leak went away too. Now I only get a drop or two after a long hot run, and I think this is mostly coming from the drain plug.
I was shocked to see that a bad PCV valve can create enough pressure to make the rear main seal leak puddles like that.
Worth looking at.
Old Oct 25, 2002 | 05:10 AM
DeenHylton's Avatar
DeenHylton
Rear Main Seal
It goes something like this:
Unbolt exhaust and motor mounts and remove fan and anything else that will get in the way of allowing the engine to be jacked up 2 inches.
Jack engine up 2 inches.
Insert small 2 X 4"s between motor mount and frame adapters.
Pull oil pan.
Remove rear main cap ONLY, do NOT loosen other main caps.
Have friend manually rotate engine with a breaker bar while you push on upper rear-main seal with a small punch or other small object being very careful not to scratch crank with punch. Make sure your pushing on seal the same direction the crank is being rotated.
Rotate new upper seal into place after lubing seal lip and making sure you have seal lip facing towards the FRONT of the truck.
Replace lower seal.
Use a small dab of silicone sealer where the two seal half butt together.
Replace rear-main cap and torque into place.
Clean oil-pan, install new gaskets and seal with silicone sealer.
Reverse the dis-assembly.
Reward your self with a beverage of choice!
Deen
Old Oct 25, 2002 | 09:18 AM
laptopgeek's Avatar
laptopgeek
Rear Main Seal
H'mmm...beverage of choice. That sounds like Miller time.... or head for the mountains of B-U-S-C-H....
Dean - the manual states to skooch the lower seal up into the upper seal bore a little ways on one side and have the upper seal skootch down a little bit into the lower bore...so all the mating surfaces don't "match up" --- have you ever done that?....
Old Oct 26, 2002 | 01:10 AM
Superdave's Avatar
Superdave
Rear Main Seal
laptopgeek, I used this method when my son and I rebuilt our 460 and it worked out fine. Not a drop of oil.
Old Oct 26, 2002 | 06:19 AM
DeenHylton's Avatar
DeenHylton
Rear Main Seal
Laptop, yes I normaly do. I'll push one end down around 1/8" below the parting-line of the main-cap.
Old Oct 31, 2002 | 07:28 PM
priley's Avatar
priley
Rear Main Seal
Thanks for the replies. I'll check the PCV first, and if that doesn't do it, thanks for the good instructions. I appreciate the help.
Paul Riley
Old Oct 31, 2002 | 10:35 PM
phantom429's Avatar
phantom429
Rear Main Seal
