Fuel leak ? ? ? ? ?
Old Jan 5, 2008 | 09:35 PM
jwearly's Avatar
jwearly
Fuel leak ? ? ? ? ?
The last several days I have found a spot on my driveway. Not pink like trans fluid, not Oil.
Help, I think I have a fuel leak, but don't know where to start looking.
It is definately not coming from the fuel lines running along the inside of the driver side frame rail.
Looks to be forward or the trans, but where should I look?
Old Jan 5, 2008 | 09:42 PM
670johndeere's Avatar
670johndeere
You might want to check the fuel bowl drain valve. It is the yellow handle valve located at the rear left of the fuel filter bowl. This is the housing under the powerstroke cover in the center of the engine. Look around the valve for leaks, and also there is a small tube running down the engine from it. There are o-rings in this valve that tend to go bad after time. If you do a search for fuel leak, you will find tons of topics in this matter. Here is a link on how to fix it.
http://home.centurytel.net/sabre/drainvalve.html
Old Jan 6, 2008 | 06:59 AM
JLDickmon's Avatar
JLDickmon
big 10-4 on that
be the best place to start looking
Old Jan 6, 2008 | 07:34 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
J.W.
If you need o-rings I have them. I am in Willis, just up the road from you.
Old Jan 6, 2008 | 12:04 PM
hefmo's Avatar
hefmo
Hi, I am in the process of changing this valve with a new one , I removed the old one and no orings are on it, just traces of yellow orings ,but there is orings ion the assembly on motor that valve came off of,do these get removed or do I leave them. thanks ,please reply asap.
Old Jan 6, 2008 | 12:11 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
if you removed the lever assy and no orings are inside of it, than they got stuck inside your fuel bowl, remove them and clean it up with the rag, push new orings in a valve assy and reinstall
good luck
