69 mongrel
Old Jan 5, 2008 | 03:03 PM
Mike in Ohio's Avatar
Mike in Ohio
69 mongrel
Hello guys, I'm new here. I just got a truck to play with acouple of weeks ago. The title and the door tag say it is a '69 f100, the 8 lug axles and the huge brakes say it's a f250. To top it off it has a 460 in it with I think a c6 (been too cold and wet to go out and crawl underneath to get numbers). So it is a mongrel but so far I love it.Now for the down side, it shows almost no oil pressure at idle when it warm. When going down the road it stays at about the center of the O in the word oil on the guage.It seems to run good and have plenty of power but I'm guessing it needs rebuilt. In the meantime I found '71 390 in the local paper, will this bolt right in or is the bellhousing and or mounts different? Or should I just run it like it is till it starts making funny noises? Thanks alot and I'll probably be bugging you guys alot. Mike
Old Jan 5, 2008 | 03:31 PM
gnwalker's Avatar
gnwalker
The 390 wouldnt be a direct bolt in. As long as the oil pressure is in the normal range on the gauge I wouldnt worry about it if you're happy with the way it runs. Just make sure the oil is topped off and ride it out
Old Jan 6, 2008 | 06:51 AM
jowilker's Avatar
jowilker
Sorry gnwalker, but the 390 will not bolt in without tranny and engine perches being changed also. Two completely different engine families.
I do agree that I wouldn't worry too much just yet, as long as it isn't loosing oil by the bucket or knocking real bad, I would drive on and enjoy the big gas loving power house. IMHO
John
Old Jan 6, 2008 | 08:02 AM
Redcat Diesel's Avatar
Redcat Diesel
Hey Mike, You might try checking the oil pressure with a mechanical gauge.It could be something as simple as a failed sender.
Mongrel
Aug 16, 2011 10:30 PM
Mongrel
23
Mar 7, 2011 05:49 PM
Mongrel
Feb 10, 2011 02:43 PM
msmith53
Sep 7, 2009 08:08 PM
msmith53
29
Aug 28, 2009 08:25 AM
