Funny Noise...HELP
Old Jan 5, 2008 | 02:45 PM
gregtx's Avatar
gregtx
Question Funny Noise...HELP
Used my truck this week to pull a light trailer and load...now I got a funny noise I've never heard before...
It's a chirping noise...between 35 and 55 mph....same pitch and same pace....doesn't increase or decrease with engine rpm...not present below 35 or at idle. It's an '03 7.3 4x4 with 95,6 on it.
Any ideas or information is greatly appreciated...thank you all!!!
Greg
Old Jan 5, 2008 | 02:55 PM
ron01sd's Avatar
ron01sd
did the trailer have brakes? sometimes when i pull a trailer with no brakes my brakes will squeak for a couple weeks then there silent again(to much stress on just the truck brakes i guess). you might want to check you u-jounts in your driveshafts and the carrier bearing if you have one.
Old Jan 5, 2008 | 05:01 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Did this happen primarily when the engine was under a load, probably below 1800 or so RPMs? If so this is called turbocharger compressor surge. It happens when the turbo is producing boost and the engine is not spinning fast enough to "eat" up the incoming air, The stock design on the turbo is far from efficient as the wheel and housing is not matched (to make it quieter in stock form). Either you change out the wheel for $60 and "move" the point at which it surges, or you replace the housing for $400 to mechanically eliminate the surge issue. Or, if you want to experiment this, if you have it occur again, downshift a gear and see if it goes away.
gcozmo
2004 - 2008 F150
35
Jan 9, 2010 12:36 AM
GregBam
6.4L Power Stroke Diesel
16
Jun 3, 2008 07:21 PM
mrpositraction
2004 - 2008 F150
15
Apr 8, 2008 07:05 PM
01RangerGuy
1983 - 2012 Ranger & B-Series
Oct 10, 2006 09:49 PM
FiveO
1997 - 2003 F150
Jul 27, 2003 11:42 PM
