T-case ?
Old Jan 5, 2008 | 01:11 PM
dixokai's Avatar
dixokai
T-case ?
Are the T-cases the same on the back of E4OD and ZF trannies? If not anybody know the differences?
Old Jan 5, 2008 | 01:44 PM
fordfaninIL.'s Avatar
fordfaninIL.
Ford uses two different t-cases, borg-warner and new process. I believe that they should interchange as long as you get the same ratio, same model (NP or BW), and manual or electronic shift.
Old Jan 5, 2008 | 02:12 PM
dixokai's Avatar
dixokai
I believe I have the NP on the back of an E4OD. I'm gonna put in a ZF. So it should bolt on to the ZF?
Old Jan 5, 2008 | 02:21 PM
fordfaninIL.
I think it will. The bolt pattern should be the same, but I am not sure about the output shaft dia. and spline count.
Old Jan 5, 2008 | 10:05 PM
dixokai's Avatar
dixokai
Bump... Anybody know about the spline count and shaft diameter?
