Sponsored by: Auxito
ball joints
Old Jan 4, 2008 | 10:15 PM
00fordman16's Avatar
00fordman16
ball joints
how is a good way to tell if you need your ball joints greased or if not regreasble u need new ones. also how do u tell if you got regreasable ones or not?
Old Jan 4, 2008 | 11:14 PM
steve(ill)'s Avatar
steve(ill)
jack the truck up and put a stand under the A frame on one side or both. let it down so tires are 2-3 inchs off teh ground, and truck has a-frames setting on jacks, not truck frame. tires are just hanging there, but in the "run" positon...get a 2 x 4 about 4 ft long. push 4-5 inches under the tire, then pry up on the tire to raise it up and down a few inches. have your buddy look at the ball joint top and bottom a-frames. might help to put a finger at the joint. if you feel it or see "extra movement" like 1/16 or more, your worn. if you see 1/8 inch or more, now it is time to change... there is a grease zerk on the bottom of the bottom joint and the top of the top joint, if they have been changed.
