Problem with 4wd
Old Jan 4, 2008 | 11:16 AM
PowerLines's Avatar
PowerLines
Problem with 4wd
Okay, this is a little hard to explain so bare with me. When I put my truck in 4wd and turn a corner, the front end jumps,jerks or pulls pretty hard not sure how you'd describe it. I have problems in normal drive with my tires rubbing but that's if I crank the wheel. I'm not cranking the wheel when this happens. Anyone have this happen before?
Old Jan 4, 2008 | 11:22 AM
95psd's Avatar
95psd
They will do that if you are hard ground, and the tires can not slip at all. Were you on pavement when this happened?
Robbgt's Avatar
Robbgt
Yes, does this on all the truck in 4wd if your on dry pavement and turn the wheel. this is because during the radius of the turn the front/back tires (depending on open, LS diff, both do it) will be turning at the same speed, while in a turn, technically the front tires while turned should be at a different speed. Ok well that probably didn' make much since. Hopefully it did. but yes if your on dry pavement this will happen in 4wd. hope this helps!
-Robb
EDIT: guess i'm a little slow today... 95 PSD's got it
Old Jan 4, 2008 | 11:30 AM
PowerLines's Avatar
PowerLines
it happens on snow when turning a corner as well as dry pavement
Old Jan 4, 2008 | 11:53 AM
tjbeggs's Avatar
tjbeggs
its normal to hop like that in 4wd even on snow in tight corners. Do it on dry pavement and you might break something! It will even happen with just the hubs lock but in 2wd but not as bad.
Old Jan 4, 2008 | 12:16 PM
BadDogPSD's Avatar
BadDogPSD
I agree with the others that this is typical when turning while in 4wd.
Did the truck just start doing this? How's the front end? Might be a
good idea to check the condition & lube your axle u-joints.
Old Jan 4, 2008 | 01:37 PM
Neal 97 250's Avatar
Neal 97 250
It is normal. You probably didn't notice it in the mud or on grass since that allows the tires to slip easier than pavement or packed snow.
Old Jan 4, 2008 | 02:42 PM
IceboxFX's Avatar
IceboxFX
dont worry my truck does it too. its normal.
Old Jan 4, 2008 | 06:46 PM
PowerLines's Avatar
PowerLines
okay thanks guys, that makes me feel alot better!
El Camino Man
Oct 4, 2013 07:43 AM
Stinger10
May 20, 2011 04:48 PM
CLIFF1989
Nov 18, 2009 05:12 PM
RIKen822
Dec 12, 2005 06:32 PM
