Diesel Smell post....(another one)
I have read through quite a few posts about changing out the O-rings in the seperator valve but have not found anything with pics to help make it more clear to me, (first diesel). I am looking for this because the other day, one of my co-workers walked by my truck about an hour after I had parked it and he said he could smell diesel fuel from about 6 ft away. I went out another hour later and could barely smell it and only on the passenger/front and front of the truck. I am assuming that it is this o-ring issue, but just want to be sure. On occasin, I get the smell inside the cab but it clears up pretty quick when I head down the road and only when i have let it sit to warm up in the mornings. Any thoughts ?
Here's a link to the o-ring fix, with pictures and a write up. http://home.centurytel.net/sabre/drainvalve.html
Also here is a link for alot of useful info you might need in the future. It was made up from some very fine guy's on this site. That is where the o-ring leak fix came from.
http://7point3.com/Mods.aspx
I had a similar problem once where I could smell diesel. Turned out that fuel filter cap was weeping a little while the truck was running. The fuel was running down the sides of the fuel bowl and puddling in the valley. To find it I had to start the truck and then closely watch the fuel bowl assembly and I saw it weeping.
on
Good idea...Since my o-rings aren't in the mail til tomorrow, I will pick up a filter before then so I have it ready to replace. Now that is the water/fuel seperator filter right? Or is there another fuel filter in the same area?
Nope...No mods....YET!!!! I just about ordered my DP-Tuner but then my wife caught me.... She kept trying to give me some BS reason not to order it then she fianally caved....My B-Day is coming up and she is working with my brother to get me the tuner. So I will behave and wait...and chewing my nails until I get it. Can't wait!
Billybob, when you put that new filter in make sure to O ring is put in correctly. Go to Guzzle's site for photoes. It almost seems like it should go the other way, but the bevel goes up. Also... have you recently started using BioD? My O rings failed "shortly" after I started using it and other have said the same. On advise from here I ordered Viton O rings which are supposed to hold up better... no problems since and it was an easy job.
