tool to replace injectors??
Old Jan 3, 2008 | 06:13 PM
tumbleweed2's Avatar
tumbleweed2
Does anyone have a link to info on replacing the injectors. A pic of the tool to pull them out.
And what does it take to get a cup out if it is cracked? I got white exhaust and a more knock than usual in idle. Also coolant level is dropping, and none is on the ground.
Thanks for help,
Ryan
Old Jan 3, 2008 | 06:18 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
you ask you got it
https://www.ford-trucks.com/forums/4...rs-are-in.html
https://www.ford-trucks.com/forums/4...injector+rings
and all you need is a few rags and flat blade screwdriver to pry them up, and rubber malet or wodden handle to pound them in,
make sure if you pulling them out you got all sets of o-rings for them, and before you put them back in remove Glow Plugs and crank it over with the big wrench or brakerbar to clean out fuel and oil from the cylinders
the injectors go in easy once you lubracate the orings in a oil, well i would say and than tap them with wooden handle, and job done
hope this helps,
ask if you have more Q
Old Jan 3, 2008 | 06:20 PM
PETE'S_6.0PSD
and if yuo need injector cups replaced you can get a tool to pull them out and reinstall them. ill see if i can find a link for you .
i think you can get it in FoMoCo dealers.
Old Jan 3, 2008 | 06:39 PM
Orezona's Avatar
Orezona
This may help you also http://www.swamp-donkey.biz/
Old Jan 3, 2008 | 06:45 PM
tumbleweed2
That what I wanted to hear. I have a big mess and dont know what to do. I took to stealership and .....i dont want to talk about it. Anyway, thanks. I feel like I just lost an o-ring on a #2 injector. Its loud and smoking white exhaust. I need to get guts and pull it out. Darn truck is at shop now. I dident want to get into it and find out a cracked cup or something. I just want it fixed right.
Thanks,
Ryan
Old Jan 3, 2008 | 06:57 PM
medhvac's Avatar
medhvac
Thanks,
Ryan
i just went thru that same thing #2 injector! u dont need a special tool to pull it just a pry bar!its easy i did it!
Old Jan 3, 2008 | 07:10 PM
medhvac's Avatar
medhvac
good info all i used from them was the pry bar! the oil u lose in the cylinder will burn off!
Old Jan 4, 2008 | 09:31 PM
tumbleweed2
Thanks to all who helped. It was really not to bad at all. I replaced #2,4,6 and 8 injectors. It fixed the problem. It took 4 short trips to purge all the air back out. I cant wait to do the passenger side when I win the lottery.
Thanks again,
This site saves us all so much time and money,
Ryan
