Cooler idea... maybe
Old Jan 3, 2008 | 12:20 PM
Talyn's Avatar
Talyn
So, I've yet to hear this even be thought of.
Why are we not cooling air into the motor with the AC system?
Atleast in a gas engine cold air + Fuel = more HP, and i know hot air into the cylinder on a diesel spells high EGT's and i'm sure some power loss.
If were running intercoolers for air, why not use the freon in the system of the truck to cycle for cooling on an air intercooler?
Does this make sence?
Even running a liquid cooled setup for the air, to have it cooled by the freon would employ the same idea.
Old Jan 3, 2008 | 01:34 PM
Neal 97 250's Avatar
Neal 97 250
I have wondered if it would cool the egt's. I guess it is possible with enough engineering.
Old Jan 3, 2008 | 03:35 PM
tjbeggs's Avatar
tjbeggs
The extra weight and parasitic load of running another compressor would off set the benefit I think. Plus the engineering needed would be exstensive. They do make them for ricer's but they are far too small to use on a PSD. There are air to water intercoolers as well that are more effective and usually cut down on tubing lenght (less lag) but they are also pricey.
Old Jan 3, 2008 | 09:33 PM
Talyn's Avatar
Talyn
I was talking about useing the existing AC system, not adding another compressor.
Though, a cooling jacket on a turbo would be sweeeeeet for cooling the air.
Old Jan 3, 2008 | 11:13 PM
Sangetsu03's Avatar
Sangetsu03
Here in south Florida we value our AC. Christmas here was in the 80's, you can imagine what the summers are like.
"Aftercoolers" are used on many supercharged engines. Compressed air from the turbo is blown through a watercooled intercooler. The water is pumped from a surge tank into a small radiator, and then through the intercooler. Ice can be added to the surge tank for improved cooling.
Diesels run a significant amount of air though the turbo and associated plumbing, and once compressed by the turbo the air becomes even hotter. You would need a very large AC evaporator to keep up, along with a larger compressor and condensor.
Old Jan 4, 2008 | 07:49 AM
tjbeggs's Avatar
tjbeggs
Yep the existing system wouldn't be able to handle the heat load of intake air even if you completely removed its cooling duties from the cab.
Old Jan 4, 2008 | 07:52 AM
Neal 97 250
I guess that is why it has never been done. That concept has crossed my mind before but never chose to follow up. Thanks for asking the question.
Old Jan 5, 2008 | 09:06 PM
Talyn's Avatar
Talyn
Idea's thats what i'm good for.
Though i'm tempted when i get a PSD to go crazy on coolers.
Old Jan 5, 2008 | 09:42 PM
scatgo's Avatar
scatgo
Sombody needs to try it. I've thought of this too. Neal, just think of all that cold air pumping out of the vents in your cab being pumped right into your intake. It would have to have do something for power.
Old Jan 5, 2008 | 10:10 PM
westtntrucker's Avatar
westtntrucker
http://media.ford.com/newsroom/relea...?release=14096
Ford already has this concept. First toyed with on the '93 mustang and then on the 2004 F150 lightning. Its called a supercooler. Using the trucks A/C to provide a 45 second burst of HP up to 500/550.
Old Jan 5, 2008 | 10:30 PM
scatgo's Avatar
scatgo
You see that Talyn?! Maybe you should work for Ford! Maybe if we all knock our heads together once and a while we can get some of the things we just think about to work for us. Neal, FOLLOW UP next time you never know.
Latter................
Old Jan 7, 2008 | 08:22 AM
Neal 97 250
Thanks for the link west tn It seems ford has already tried it but I guess it is good for short term competition. Similiar to NOS cooling but regenerative and eco friendly. Very interesting stuff. Next mod possibly...??? Post up someone
Old Jan 7, 2008 | 09:23 AM
Talyn's Avatar
Talyn
I can't even think of how to redirect the air.
I got the ideas, and not always the way, Then other times i have the idea and the way and not the material and the tools.
Can't wait till i get that stick welder down here. "storing it for the neighbor" really means. Thanks for the welder partner. =)
Buzz Box For the Win!
