Thermostat??
Old Jan 3, 2008 | 12:16 PM
86 F-250 Diesel 4X4's Avatar
86 F-250 Diesel 4X4
Thermostat??
OK, all you guys up north, don't laugh -- my 86 6.9's heater is pumping out just slightly warmer air than the outside temp. Hasn't really been a problem until the last couple days when we've seen morning temps at or below freezing.
Could this be a thermostat problem?? How hard is it to replace?? From doing a search on this topic, sounds like the only replacement part would be a Ford thermostat and not any autoparts store brand replcement.
Mike
86 F250 6.9 4x4
AB, NC
Old Jan 3, 2008 | 07:50 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Could be blockage in the heater core.
How warm are the hoses to and from the heater core?
Could also be something holding the blend door open, letting in to much outside air.
Old Jan 3, 2008 | 10:21 PM
AndysFords's Avatar
AndysFords
Is your temp gauge reaching operating temp? If not, thermostat would be the first thig to check.
Old Jan 4, 2008 | 07:12 AM
86 F-250 Diesel 4X4
Temp gauge reaches it's normal position. I'll check temp of the hoses. How do I check the blend door??
Old Jan 4, 2008 | 11:01 AM
royzell's Avatar
royzell
Hi all,
'hope you don't mind me 'piggybacking' on this thread, but I have a similar issue with my 88 7.3 The gauge usually runs about 1/4 of the way up from cold , but it takes a very long time to get heat from the heater and it doesn't seem to get as hot as a few years ago when I bought the truck. I'll try the things suggested already, but I was thinking thermostat too.
Thanks
Old Jan 6, 2008 | 10:23 AM
86 F-250 Diesel 4X4
I checked the heater hoses -- To the core=hot, From the core=cool.
I checked the blend door, appears to be opening and closing as advertised.
If the one heater hose is hot and one is cold could it be the core??
Old Jan 6, 2008 | 10:42 AM
PLC7.3's Avatar
PLC7.3
The heater core is a straight through flow...... so yes it sounds like it is plugged. You can try cleaning it in place by back flushing in both directions until a very good flow is accomplished.
