anyone's FE useing E85?
Old Jan 6, 2008 | 09:03 PM
  #31
RustyTrustyF150's Avatar
RustyTrustyF150
good info , maybe a heat shield blanket of some kind in the cold months ,,,
Old Jan 7, 2008 | 09:55 AM
  #32
krewat's Avatar
krewat
FTE Leadership Emeritus
Not that it's cheap or easy, but a way to get around that cold-start stuff:
Put a second gas tank in, even a small one. Put in high-octane gas, even race gas if you have to. Electric fuel pump.
Solenoid valve at the carb to switch between gas or E85.
This way, you could start it on gas, get it warm, and then switch over to E85.
Any valve that would accomplish this has to be mounted as close as possible to the carb, so that not too much E85 winds up going down the cylinders before you get to the real gasoline. Might even switch over BEFORE shutting down the night before.
This way, you can fill the small tank with the highest octane stuff you can find, enough to warmup and idle, but not carry a load.
Another way to achieve the valve at the carb would be a cable-operated manual valve. Using a choke cable, you could run the cable up to the valve near the carb.
Too much screwin' around with flammables on the motor though.
F350FordToy
6.2L V8
Jul 21, 2021 07:50 PM
krecak
6.7L Power Stroke Diesel
Feb 2, 2017 05:05 PM
scottperkins
1997 - 2003 F150
Jun 29, 2016 10:33 PM
staysbroken
Alternative Fuels, Hybrids & Mileage
17
Sep 10, 2007 08:06 PM
mr. dave
General Automotive Discussion
Dec 23, 2005 08:37 PM
