Power Window issue...
Old Jan 2, 2008 | 07:31 PM
o2civic's Avatar
o2civic
Guys:
My power windows do not work. No motor.. no clicking.. nothing. The Power Windows do not work at any door switch.. the window lock is not on. It's not the 30a fuse because the moonroof works just fine.. The lock button works.. the lights on the switches on the driver side are on.. I don't know.. any ideas?
Old Jan 2, 2008 | 09:08 PM
FTE Trigger's Avatar
FTE Trigger
Im showing another fuse for the CJB (5 amp.) which also ties into the power mirror switch....
...And it also seems odd IF all the regulators went out....
Old Jan 2, 2008 | 09:13 PM
FTE Trigger
Also.... what year is this on? I'm showing a few different schematics between years and body styles..
Old Jan 3, 2008 | 04:53 AM
o2civic's Avatar
o2civic
Thanks for the help boss.. This is for a 2004.. new body style.
Old Jan 8, 2008 | 08:45 AM
f150vt's Avatar
f150vt
Probably the switch in the door. I replaced mine last night sounds like same problem, dealer said they change them a lot..
Old Jan 8, 2008 | 09:56 AM
mohrf1507's Avatar
mohrf1507
New 08 Crew Cab
My Rear Driver Side Door Window Did Not Work And The Cause Was
Motor Inside That Door Came Unplugged. Is Your Problem All4 Doors?
Old Jan 14, 2008 | 12:22 PM
f-150 on 22's's Avatar
f-150 on 22's
I had a problem like that with my 06 crew cab, but it was only the driver window. So, I pulled the switch apart and saw that the connectors were not making contact so I just bent the little metal tab and now it works just fine!
Old Oct 21, 2008 | 11:04 AM
GRNMSTR's Avatar
GRNMSTR
Check the plug that is located in the Door Jam on the 2004 F150's and newer. There is a wireing block that tends to corrode, apply a good amount of Die-electric grease to it and check all of your contact pins and sockets to ensure that non are broken from corossion. My, window on the Pass side stopped working and that was what the problem was.
mrjimbov
Electrical Systems/Wiring
Nov 23, 2014 07:20 AM
Black 07
2004 - 2008 F150
Jun 1, 2012 04:13 AM
stm250
Oct 19, 2007 09:58 AM
3vanman
Aerostar
Dec 21, 2003 04:55 PM
