trouble installing new solenoid
thanks,
Adam
Ford used on many engines what's called a "movable pole shoe" starter. When you turn the key to "start" what happens is that the solenoid gets the voltage to the 's' terminal. That closes the relay/solenoid's contacts and sends battery voltage to the terminal on the starter. That creates a good size magnetic field with the windings of the starter which pulls the "pole" down and that part pushes out the small gear to the flywheel/flexplate ring gear.
Over time it's possible the starter windings have become a bit weak, and might not create enough of a 'magnet' to pull that movable pole down into place---Result? It'll spin, but not contact the ring gear. (it will remain retracted)
I'd suggest pulling the starter and taking it to a parts shop that offers free testing.
Also the usual stuff...make sure the battery contacts are totally clean and tight--and make sure the ground strap from the battery is making solid contact.
S-
- The operator closed the key-operated starting switch.
- A small electric current flowed through the starter relay coil (part in error as noted-the starter relay coil IS the soleniod mounted on the fenderwall), closing the contacts and sending a large current to the starter motor assembly.
- One of the pole shoes, hinged at the front, linked to the starter drive, and spring-loaded away from its normal operating position, swung into position. This moved a pinion gear to engage the flywheel ring gear, and simultaneously closed a pair of heavy-duty contacts supplying current to the starter motor winding.
- The starter motor cranked the engine until it started. An overrunning clutch in the pinion gear uncoupled the gear from the ring gear.
- The operator released the key-operated starting switch, cutting power to the starter motor assembly.
- A spring retracted the pole shoe, and with it, the pinion gear.
That better describes the operation of this starter. (thanks to Wiki for the info)
http://www.partsamerica.com/product_images/aap/WRW/120.pdf
From advance auto's tech-tip area. Some information regarding possible issues due to those 'usual suspects' (battery, cables, etc...)
You can try a different soleniod and see if that's the problem. I did get ours via Advance, and it is a made in the USA product. (I agree with the prior postings about china's knock off products--their quality control is sorely lacking) Keep in mind that Advance sells the same solenoid type, made by several different brands.
I'd still give the wiring a full check over again and make sure all the contacts are good and tight.
Use a voltage test light, grounded with the battery's negitive. Remove the wire 'S' at the soleniod and insert the probe into that wire end. Have a helper turn the key several times to the 'Start' posistion. If the ignition wireing is correct--the light should flash "ON" every time the helper turns the key to "Start". And it should go "OFF" when the key is released.
My personal next test would be to inspect the wireing at the starter itself and make sure all connections are good and tight. Sadly people do forget when changing out battery cables that the starter cable takes a lot of abuse as well--and many do not bother to change it out. (see the tech tip from advance, it's helpful)
hmmm....you also never answered the question of what started this whole wing-ding? What was the starter doing/not doing before you changed the soleniod?
S-
EDIT: Wiki is wrong with #2. Ford did not do-away with the soleniod persay-- The soleniod is used--and the poster calls it the 'starter relay'. Not sure why it was goofed up? However the starter itself does not have a built in solenoid--it's seperate and bolted to the fender near the battery.
Starter whines, but nothing happens: defective starter drive, and thankfully, there's only one...for all engines. D6PZ-11350-B (Motorcraft SD-302).
[D6PZ-11350-B replaced (in 1976) the earlier starter drive used from 1964 = C6VY-11350-A]
Starter whines, but nothing happens: the teeth on the flywheel (or flexplate) are stripped.
Rocking the truck back and forth by hand while it's in gear, sometimes will move the flywheel just enough to get to teeth that aren't stripped.
it was only working about 50% of the time. the others times i had to bang on it a little, or even use a screwdriver to go around the solenoid. Should i just go ahead and put a new starter on?? i know that everything is hooked up right and i bought new terminals for my battery and tightened em down good. Its just making the whirring noise, sounds kinda like a loud fan, underneath the engine. thanks for all the help, ya'll are great
it was only working about 50% of the time. the others times i had to bang on it a little, or even use a screwdriver to go around the solenoid. Should i just go ahead and put a new starter on?? i know that everything is hooked up right and i bought new terminals for my battery and tightened em down good. Its just making the whirring noise, sounds kinda like a loud fan, underneath the engine. thanks for all the help, ya'll are greatHere's a nickels worth (less tax) of free advice. If you want to know if it's a ring gear or starter? You can take an socket on a breaker bar and using the crank pully? Give the engine a turn a few degrees. The idea being that if that section of ring-gear teeth are broken? Turning the engine with a breaker bar should get that bad section past the starter area--and hence should allow the starter gear to engage and turn the engine.
Sidebar note: I've seen a lot of broken teeth on a ring gear---but I've never found a ring gear itself busted off the flywheel/flexplate. If it's got broken teeth on the gear? Just turning the engine about 1/4 or so a turn? That'll be enough to find out what's what.
Also if you replace the starter? Do yourself a HUGE favor and change out the main starter cable at the same time. It does not cost a huge amount for that cable, and it's good peace of mind.
Best regards
S-
