Is Rag Joint Sealed Unit?
Old Jan 2, 2008 | 06:27 AM
mahanson's Avatar
mahanson
I'm replacing the rag joint on my 72 F100 4x2 (power steering). It was time...it ripped in two as I pulled my steering gear away.
The steering gear half doesn't have any bolts/nuts visible on the clamp.
. It has what may be dome-like covers over the bolts, but it really appears to be a seamless pressed on unit. Am I not seeing something? Do I have to get a whole new unit (versus replacing the rag)? If I'm stuck, where can I get one? Dennis Carpenter doesn't cover that year. Thanks for any suggestions...I'm stuck on blocks in the meantime.
Matt
Old Jan 2, 2008 | 08:22 AM
jowilker's Avatar
jowilker
Matt, You should be able to get one from your favorite parts house, or local Ford dealer if you want to pay extra.
Da Dummy will be by in a minute with the exact part number so you can dazzle the counter person with brilliance.
Once you have the replacement you will see what you have to do to replace it.
John
Old Jan 2, 2008 | 09:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Exclamation Steering Coupler 1969/74 F100/350 2WD
John
DAZZLE AWAY!!
C9UZ-3A525-A .. Steering Coupler
Fits: 1969/74 F100/350 2WD.
From: FTE sponsor DIRECT FORD PARTS (Gaudin Ford-Las Vegas, NV)
Ford suggested retail price: $72.03 / FTE member net price: $50.91
Autoparts stores usually only sell the rubber portion, then you have ta fit it to the old parts. Before buying one a these, make sure the splines aren't worn down to a nub or stripped.
Old Jan 4, 2008 | 01:41 PM
mahanson's Avatar
mahanson
Thanks! Found the part and ordered it. It turns out I could have used the "HELP" kit, but I would have to grind and such to get the hidden rivets out. Buying a new unit is a bit more money, but I'm getting lazier and lazier.
Matt
74 F350 SCS
Feb 9, 2014 04:10 PM
74 F350 SCS
Nov 24, 2013 10:57 AM
shane_lxi
15
Sep 30, 2013 01:59 PM
1983F1503004x4
Mar 5, 2013 11:57 AM
STGFordCrazy04
May 28, 2012 05:02 PM
