Sponsored by: Real Truck
Power steering pump
Old Jan 1, 2008 | 08:31 PM
Ak68F250's Avatar
Ak68F250
Power steering pump
My dads power steering pump just put a hole in a line down at the cooler. It is -8 f below outside.
Could the pump be putting too much pressure into the hoses?
The pump will scream 2 to 3 minutess when it is colder than 0 F outside.
It does have syn in it. It did the same thing last year but the hose did not have a hole in it. THxs It is a 2006 F250 with 5.4.
Last edited by Ak68F250; Jan 1, 2008 at 08:34 PM. Reason: forgot to put the year of truck
Old Jan 1, 2008 | 08:37 PM
medhvac's Avatar
medhvac
man thats cold, nothing works good when its that cold!
Old Jan 1, 2008 | 09:09 PM
Ak68F250's Avatar
Ak68F250
Thats not cold yet it can get to -30 f or colder and with windchill even colder.
Old Jan 1, 2008 | 10:49 PM
BareBones's Avatar
BareBones
Yeah, we even rarely see thirty below in Minnesota. The equipment needs to be able to handle it....
Old Jan 2, 2008 | 09:32 PM
Ak68F250's Avatar
Ak68F250
anyboy have any problems like this and is it covered by warrenty?
Old Jan 3, 2008 | 12:06 AM
aldridgec's Avatar
aldridgec
The cooler comes after the gearbox so it is the "low" pressure side of the circuit. My guess would be moisture in the line or some sort of physical damage. Most likely you can get the dealer to handle it as long as you are in the warranty period.
Old Jan 3, 2008 | 03:25 PM
Ak68F250's Avatar
Ak68F250
Truck was bought new in 06 and the dealer is 400 air miles away. The dealer has been a pain the rear. We have a abs light light on since it was bought and they have been no help. There is no moisture in the steering fluid that we could see when it drained by the hole in the hose. Thxs.
