glow plug light
Do not try removing any before reading......... http://www.members.shaw.ca/k2pilot/
Rgere is a sequence to removing the GPs if suspected of being burned out...... if done wrong head removal is required............ Check recent posts here I just coverd some of that for one member last night. "is this safe to do "
When the controller fails, it usually turns the glow plugs on, burning them out.
This is the relay mounted behind the passenger side battery.
After you fix the glow plugs that are toasted, after the engine starts, remove the purple wire from the relay.
That way the controller can not turn them on.
Manual glow plugs are easy to hook up, but usually not a good idea if other people drive the truck.
They never understand push the button for 10 seconds, then start the engine.
Either they hold the button for 30 seconds, burn the glow plugs or 4 seconds and toast the starter from excess cranking.
I am telling you all this because removing the original controller is a risky thing.
It goes into the coolant passages and has been known to twist off before it comes out of the head.
If it twists off, you will probably be removing the head to get it out and block the coolant off.
To install manual glow plugs, find a fuse that is hot only when the key is ON.
Run a wire, can be small gauge to a push button or momentary switch and attach it to one terminal.
From the other terminal, run a wire to the relay terminal where the purple wire was attached.
The glow plugs are now ready for manual control.
To operate, turn the key to ON.
Push the button for 10 seconds.
Start the engine.
The push button or momentary switch needs to be spring loaded, so it can not be bumped ON and burn up the glow plugs.
Do not use a normal switch because of this.
